Currently I have Kodi 17.6. running on my Formuler 7+ . Is it possible to get Kodi 18.1 Leia. This version allows DTS-HD Master Audio pass through on my Shield .
I have installed Kodi 18.1. Upload the APK file to the z7+ and then installed it.
Display MoreThis is the proposed software change list for MOL1 devices:
Z-Series April Release (excluding Z8)
MOL1
FIX: USB DVB-T Freeview HD EPG issue
FIX: xtcodes api and m3u favorites
FIX: USB timeshift file is created if Timeshift is OFF
FIX: m3u parsing issue
FIX: Recordings stop when stream buffers
FIX: Grid EPG cells overlap
FIX: xmltv EPG parsing issue
FIX: Video format changes when timeshifting
FIX: xtcodes api VOD search not working
ADD: VOD favorites
FIX: Increased refresh rate of detailed stream info (bitrate)
System
FIX: Android Location Services
FIX: Certain system preferences reset after firmware upgrade
FIX: Resolution selection window doesn't appear when Resolution button is pressed
MOL1
ADD: VOD favorites
System
Any news when this update will released?
Never
This has been mentioned so many times...
New Z7+ update will be coming in a few weeks.
I can't understand why not.... How old is the Z7+ ??? Already Legacy?
Hello Devs,
When can we expect the new update for z7+ ? They say in march but its almost April already...
I don't see any news about updates for z7+ at all..... or is this device silently R.I.P. ?
Last year we had much updates and some betas.
But from october or november minimal.
Maby the software is almost good by so far.
It isn't. Lots of problems with Audio (dts/dd) and still no update for mytvonline. Recording channels gives problems. Pause is horrible (not play from moment you paused it, when you start watching again) , favourites loose when you use a m3u url, etc etc etc, do you want hear more?
Would be so nice when they also bring up some Z7+ betas for better performance..... Seem they only care z8 now...
Would be great to be patched this problem.... then I can use MyTVonline again.
Have same. Im using IPTV Extreme Pro. Much better then MyTVOnline and better support of EPG and SOund , pause etc.
is this a newer version than the one on the website:
VidonXBMC_V14.2.1
Maybe a idea to make a special post with all the ToDo where the devs working on.
And behind it the status: prepare, build, testing, beta testing, release or something
So we all can see what they doing...
Когда будет поддержка DVB-c через usb stick ?
ебаным корейцам уже 1000 раз этот вопрос задавали
english please
Maybe english please so everybody can read it
Yes then developers must build a better option....
english please
Hi All,
I read some issues on the Z7+ that is not solved. Lots of people buy a device and trust that it work good. They PAY for it. For some its a lot of money for some it isn't but is not issue.
To developers:
PLEASE Solve follow
Would be great to see this QUICK fix soon, and lot of users will be happy, and trust the Formuler crew... And maybe we all gonna buy the future new devices because formuler bring a GOOD product that works!!!!
For all users, please hit the LIKE BUTTON to support this post. Leave comments is ok, but this is only a massive signal to the developers that they must do something!!!
P.S.: There is a wish list. Check it and maybe you want some future options as well. Post your comment there:
When this happen (with android phones) the Wifi Hardware is broken. And this device is also with Android maybe same reaction and action.
WifI hardware module not working anymore.
Hi All,
I find out that i have 1 channel thats out of sync. but when im look for the channel i find it also at a other country, and that channel is in sync.
Maybe you can search for same channel in other country?
Thanks i will check this!
Hi All,
Im trying to install a Video-Add-On that uses the "ResolveURL" add-on. But every time when i try the Video-Add-On it stop when it want install this "ResolveURL" add-on
What can i do to let it work?
English please so we all can read it....
Display Moremaintenant cela fait 2 semaines que j'essaye d'enregistrer des programmes via "l'enregistrement programmé" EPG
formuler Z7 + et mytvonline
Je parviens à enregistrer 20 / 30min et ça se coupe
- J'ai essayé avec
- 3 fournisseurs différents (mon abo et 2 versions de test)
- nombreux canaux différents et différents jours et heures
- J'ai fait une réinitialisation d'usine à deux reprises et vide le cache mytvonline, cela fonctionne pendant 2 jours, puis tout recommence.
- résolution réglée sur 1080pp, mémoire formulée entre 466mo et 0.9me sur 1.9 GB
Je regarde sur le forum formulé en anglais et apparemment je ne suis pas seul dans ce cas. mais je n'ai pas trouvé de solution
J'ai même essayé d'enregistrer en direct sur une période de 5 heures, mais il est coupé après 1 heure.
quelqu'un parvient-il à enregistrer via le programme d'enregistrement EPG?
Merci de ton retour
same here. Since 4 days i don't get any EPG data
Also some channels are out of sync with video and audio
Keep in mind that lots of IPTV provider not allow more then 1 stream connection per account. Otherwise you will be banned.
And your question is already listed in "Wishlist / MyTVOnline"
You add the link into "Edit Link"
do you have a link with username/password in it and most of time end with : output-ts ?
Make ip static on z7+. Most of time will solve the issues
Yes same question. How to become a beta tester.
ANd will the update also for z7+?
I have that app to.
Where can i setup my providers mac link?
Cant find it???
I have only a mac portal without username and password. (Macportal so no m3u link)
You can't. It must be a m3u link. in IPTV Extreme Pro everything work. pause (on hd fhd also sound stop) recordings work. etc.
Mytvonline work great but only pause on hd/fhd is not working correct.
So you must choose whats important for for you....
Hi i also had this problem and the 1080p worked for the picture but the sound of the stream keeps playing ad if you rewind ore start play the sound is from the live tv and not from the timshift recording what can i do about that it almost works so please help me i also have a z7+ thanks in advance
Edit. It is esspaialy whit HD and FHD it records the video but the sound keeps on going also when you hit the pauze butten video pauses but sound keeps on going whit the live stream. So if you use rewind you have the rimeshifted video whit the sound of the live stream.
Second quistion does the app mytvonline update itself or do I need to push it and if so how do I do that
I have this problem also. How can i solve this?
Same problem here.... When pause the video is ok sound will continue. When resume the stream after hit play button it will continue where it play live. Sound is not sync , stop, or what ever
Did it work fine? I am a little worried since it installs a new Mac-address
Work great. Not super fancy as MyTVOnline. But work great.
Make use of static IP number. Lot of buffering problems will solved when using static IP
Oh god 🤣
It was a question because yours was not clear what you mean. Added in Future list
As we use the Time shift, the blue line in the bottom of the screen remains all the time in the image. Would it be possible for it to shrink because it is very aannoying
(Sorry for traduction)
Make it smaller so it takes less space of the screen?
Just seeing the infos like for example 1920*1080 25fps if it's possible.
Added in the list!
I have a Logitech harmony and work great with the z7+
This is add already in wish list post
