thank u for reply.
i did factory reset then followed your advice and now working ok.
thank u for reply.
hello,
i have a z + neo. there is no audio on 4k movies with eac3 5-1.
i can use a different iptv player (distroX) and the audio is good. (on the same z+neo)
i can play the same movie on a formuler Z7 and the audio is good.
i have used audio optimiser and altered the hdmi settings as described in other threads but still no go.
is the problem with the mytvonline2 app?
any ideas please
thanks for prompt reply
hello. probably a silly question but cannot find a definate answer.
is it possible to add apk apps via usb to the formuler z plus. i bought a Z nano before i realised i could not add privatevpn or other apps like smarters pro.
what is the advantage of buying formuler z7 plus as opposed to the formuler z plus
as there is quite a price difference.
thanks in advance
ok thanks for answering that question. unfortunately the option is not available in the setting menu. but at least i know why now
is it possible to stop the Z7+ automatically switching off after about 4 hours when using mytvonline ?
