well by leaving box on & timeshift off my recording was perfect.. well i guess i'll use this method...so by leaving z11 pro max on doesnt hurt..Right ??
Posts by Pittro
I Have 3 connection service...that shouldnt be an issue...i set a recording tonight w/ box left on & timeshift disabled..will post later if errors
also if i leave Z 11box on the recording its fine ..& does it matter if Timeshift on or off w/ setting recording
here is a question...when i shut down w/ stand by after setting a recording ..sometimes doesnt record ..i formatted usb flash drive w/ rufus tool..everthing is set right ..for some reason im thinking maybe z11 when turning on its not picking up my wired connection right away..therefore recording maybe not starting causing timer recording not showing up..can this be corrected ..also this was before the new beta update
with new update ..MOL 2 i try to manually record a show from epg w/ no info in advance..Show is on 12:30..Live time is 12 noon..cant record it until 1pm right ?
Carber...I'm hoping to see that change in the new update soon...would love that option...also would love to be able to record a channel that says no information (even when i know what that program is scheduled at that time) in the epg at any time with timer ...
i noticed in the new update... MOL2 you cant add channels to favorites in EPG.. the only way so far that i found out is to be on that actual channel ..hit info..then select it as favorite..seems time consuming..
update working great but in the next update it would be nice to manually set a recording anytime on a channel in epg cuz some shows are not correct for that time...also to manually set the recording timer on a channel that shows no information...that would be great ...keep up the good work
got it thanks
whats the correct way to do factory reset ??
some channels have no info... so cant record them ahead of time ..will there be an option to record them in the new update coming soon ? for ex. TNT has a live game at 8pm -10:30 which i can set but after 10:30 there is no info on EPG so i cant set the recording if game goes past that 10:30 time
can i set a timer recording manually ..for any time on a channel..lets say tcm guide is wrong..can i set record for a time to start at any time & then stop ??
Just purchased z8...Ive heard that the advanced recording option in the epg will be in new update in March is that true ??
