I answered my own question
I was using OpenVPN connect, not the full version
With the full version you can specify apps included/excluded
Its working perfectly now
Next task, get passthrough working properly with these newer kodi builds
I need to run a vpn on my Z7+ to allow uninterrupted access to my sub via MyTVOnline
I can't get settings from my provider (not a standard VPN provider, it is through a seedbox) to work in the standard android set up
Their own app involves logging in every time which is a pain
So at the moment I am using their config file in openvpn which is pretty good as it will reconnect without prompt if the VPN is enabled when the z7+ shuts down
The issue I have comes when I want to run Kodi and access my network shares as I have to disconnect the VPN. Not a problem for me but not wife friendly
In openvpn I need to enable to pointer to move the slider to turn it off which is a pain
Is there a one button solution out there or something else?
I don't really want to go to network wide vpn at my router as it will be a pain when gaming
It was actually why I went from a mag to and android box so I could run a vpn on it also
Embarrassingly my problem was my isp blocking the provider and was resolved by installing my vpn
Just received new box
Updated and max registered
Portal gets stuck loading epg
Tried manual uninstall, reboot and reinstall of MOL
Also tried factory reset
