I need to run a vpn on my Z7+ to allow uninterrupted access to my sub via MyTVOnline
I can't get settings from my provider (not a standard VPN provider, it is through a seedbox) to work in the standard android set up
Their own app involves logging in every time which is a pain
So at the moment I am using their config file in openvpn which is pretty good as it will reconnect without prompt if the VPN is enabled when the z7+ shuts down
The issue I have comes when I want to run Kodi and access my network shares as I have to disconnect the VPN. Not a problem for me but not wife friendly
In openvpn I need to enable to pointer to move the slider to turn it off which is a pain
Is there a one button solution out there or something else?
I don't really want to go to network wide vpn at my router as it will be a pain when gaming
