Posts by Mr Magoo
    I got this problems too. Never had this before on other boxes like Z10 and GTV using for years. I think there is something wrong with the software here, kind of bugs. The bluetooth of my remote stops suddenly working and box freezes. The only thing I can do is disconnect the power and put back in the cable and it works again. This happens me this week 3 times, bluetooth down and box freezes. Maybe after 5 hours or something when its on.
    Now im stopping to put down the box in standby modus and turn it off, because its happens to many times. I think it’s a software bug maybe with the Bluetooth remote only?
    Hi
    I have a simular problem, when watching it freezes I can’t do anything but restarting it by taking out the cable from the box. Same thing happens when I start upp the formuler in the morning. The picture comes upp but it has frozen and I can’t do anything with the remote. The only thing to do is pull the cable from my formuler and let it restart then usually it will work?
    Bad formuler or what’s wrong?
    I had a Z10 before and I haven’t had these kind of problems before. 😔
    Does your box state it has an internet connection? If not, try the following: if you’re using WiFI, you may need to disconnect and reconnect to your network. If you’re using a wired connection, simply unplugging your cable temporarily might restore connectivity.
    If this doesn’t work, you could try restoring factory settings. One other thing that could work for some weird reason that’s beyond me, is trying to configure your box with a static IP address. Anyone with a bit of IT knowledge knows that, in fact, this shouldn’t make a difference, but strangely enough, sometimes it does. So, it doesn’t hurt to try, I’d say.
    Got everything working after doing a Factory reset, thanks for youre reply.
    Thank you for the input👍.
