No problem with trailers here when i set Swedish in Main and Swedish in Mol2.
When choosed Dansk in Main and System in Mol2 i got No trailer either.
When choose English in Mol2 and still have Dansk in Main i got trailers. So what is the problem?
The translation in Mol2 is bad anyway so i have Swedish in Main and English in Mol2, problem solved ![]()
Display MoreHey.
The problem i have talked about with the trailers button don't show in VODs after the last update I now know why.
If I set language to English (United States)
In settings on the box. The trailer button is there.
If I change language to Danish (dansk)
The trailer button is no longer there.
Must be a bug. On my other z8 I did not update. And the language is set to Danish and the trailer button is there. On my other z8 and z alpha with the new update. This bug is there if I change away from English to Danish.
SAM can you test.
and..
Soppdk is right.
The Traler function disappears if I select certain Menu Languages in Mol2
If I select: - Settings - Swedish as Menu Language, the Trailer-function is gone.
I have tried ALL languages and only when I select English, French and Lituviu as Menu Language can I get the Trailer function.
