Try to format with easy2boot and ntfs -> http://m.easy2boot.com/download/
Is that for Linux? I don't use Windows!
I tried with LogCat but it caught nothing while MyTvOnline2 crashed!
Yes there is.
Ok, and?
The entire external hdd has to be formatted to NTFS not just the partition.
It's a single USB pen drive. 16Gb. I used 'dd' command to wipe all the drive, then used fdisk to create "GPT label" and then mkfs.ntfs to format partition to NTFS file system type.
Is there a log or some error tracking system so that I can see why the app is crashing?
I just tried with an NTFS partition and MyTvOnline2 crashes immediately. ![]()
For recording is ntfs the solution.
I'll try it today!
Check your last installed apps and deinstall not needed, maybe some app have conflict with mol2.
It might have something to do with at least one of the external devices is formatted in ext4 and it tries to record there and it crashes. But even so, the other external drive is in exFAT and it also crashes! I have to investigate further, but for now is bed time! I'll come back to the fight tomorrow!
Damn, now for some reason, when I try to record something, MyTvOnline2 crahses... ![]()
Perfect Player, smarters IPTV, IPTV Extreme, Smart IPTV.
IPTV Smarters Pro says it might not be optimized to my device.
And all those IPTV apps are only for .m3u playlists, right? My provider is not using .m3u files! It's an http one.
Use the included File Manager app and try to open the USB from there.
Ok, I managed to work it around by uninstalling that app and installing EZ File Manager. I can already record stuff in my external storage and access both storages.
Android Settings > Apps > CS File Exp > Permissions
I don't the menus exactly like that but it's like:
Android Settings -> Applications -> CS File Explorer -> Authorizations -> Storage (Slider is activated)
Some pictures:
But even with the slider activated, when I try to access the drive, it still says "Access Denied"
Do you have some issue with using FAT32 or NTFS filesystems?
Which file explorer app are you using?
Did you grand external storage permission to the file explorer app?
I'm using CS File Explorer. Where do I set permissions? I tend to run away from Windows world. I have "a thing" for Linux world! ![]()
Ok, I have formatted a pen drive as exFAT and tried to access it in my Formuler Z8 and my file explorer says "Access denied". What else do I need to do?
Just for curiosity, you know an app for IPTV called "Gotit"?
Not yet, will come with next or after next update! Please note, for such feature, recording and watching other channel you need multisub from your provider. In clear words one sub with two lines. You should check this first with your Provider.
So that means that in addition to the box be able to record a show an change channel, I also need to pay for a second line to my IPTV provider so that the feature can fully work?
I don't know why ask Android. Don't see this as any issue just format to NTFS.
Not possible, but you can use other iptv app while mol2 is recording.
What other IPTV app would you recommend?
Ok, one other question about recording. Isn't it possible to change channel when the box is recording?
I already saw that. But why there is this limitation about filesystems? Why, as an Adroid box, it doesn't support ext4 and other Linux based filesystems?
So, recording is not possible for external drives formatted in other file systems other than extFAT? I have an external drive formatted in ext4 and I can see and play the contents using VLC app but I tried to record a kid's show and it seemed to be recording but I can't find the show anywhere. The "Recordings" menu of MyTvOnline2 says it's empty.
In addition to the steps I did, it is possible that if you try to write in that shared device, you lack correct permissions.
What I did, and also for convenience, was to mount that shared device in a local folder and for that to work properly and don't have write permission issues, I mounted the device with the following options:
Just open windows explorer and insert > \\box.ip.address\ and not //box.ip.address/
or
under Network you see device like " Android _K8Dxxx" just click on it.
I'm not in Windows. I'm in Debian. And apparently, my laptop takes some time to see the shared folder. Like a couple of minutes. But I think that's all.
Well, for some reason, I can see the folders but I can't enter any folder "below" ..../share/......
It says:
"Could not connect to host for smb://ip.of.formulerZ8//share/media_rw/sda1/........"
What internal-external ip? The z8 only has dynamic or static ip. You can assign your own static ip adress or dynamic.
By internal I meant static IP.
Anyway, I got it. I'll share the steps.
1 - Enable Samba service in your Formuler Z8 Settings.
2 - In your PC, open your File Explorer an edit path an replace by: smb://box.internal.IP/share/media_rw/sda1 (linux way)
Notes:
1 - If the above path doesn't work, use your favorite file explorer of your Formuler Z8 to find out the correct path.
2 - Windows way, just replace '/' by '\'.
That's all
That link with the internal IP is not working! I'm going to try with the external IP.
Internal or external IP?
I have activated Samba services and plugged in my HDD to the box. Now, where am I supposed to find the HDD in my laptop? What should I do so that I can see the HDD content in my laptop?
How is the firmware updated? Via USB pen? Where can I see if my firmware is updated?
If you mean to your local network then it is possible. Just turn samba service on.
I mean an external HDD I have. It's 1TB an it could be used to save recordings and movies and music to eventually play in my Tv with the box!
Hello.
I just bought a Formuler Z8 and I was thinking about the possibility to connect an HDD to its USB3.0 port and share it over Wireless connection so that other devices could access to the HDD contents,
Is this possible?
