Yes it dose
Posts by Den123
Dont understand. I have tried. Different players still no joy
Good of you Sam well said
Any help please guys. On the z8pro. The 4K vod plays perfect But on the GTV the vod 4K will not play. Same provider. Thanks all
No my friend still not playing
Hi guys I can’t play any 4K movies they won’t play any help please settings ect thank you
You can set it up on the router no app reqired
Thanks mate. But in router settings think you have to set router up can’t get my head around this thanks mate
Hi all could anyone tell me how to set up wifi 6. On GTV And asus router please. Router.Ax88u RT-Ac88u RT-AX88UAX88U
Black tape over led
When it’s ready
Mol2. Slow since update anyone else same guys
Format with Rufus
Urgent is that just to get noticed lol
Surfshark vpn. Load this have free. Trial
Updated 02F9 2021 Version IR Smart learning Luminous Glow in the Dark Remote Control for FORMULER GTV / Z8 Pro/CC / Z8 / Z Alpha/Z+ Neo / Z7+5g / ZX5g / Z7+ / ZX/Z+ / Z Nano by FORMULER SALES UK
Z8 pro sorry
Think z8 is better box
Lol not really Sam you are the top man
eBay. Just search formuler GTV
Hi guys seen this formuler GTV 2021 updated model. ???? Is there such model
Hi guys Iam going through a bad spell. 3 providers. All black screen. Hello please
Hi all what is the best hdmi cable you are using with the GTV. Or what should you recommend please
Thanks Sam tried that still same. So just turned off vpn. Then put on nordvpn same. So turned off nord and put surfshark back on next think it all came on brill really strange thanks mate
Hi Sam. Just found out the portal I had was working fine then stopped have just loaded a different app to see if it works and it worked. So won’t work on GTV but works on app for iPad. Why is this can I do anything Sam thanks
Hi all can anyone help portal loads up epg ect but there is no pic on the tv coming through
All sorted guys reformatted with Rufus
Hi all I have a 128gb stick have formatted with Rufus When I presss record. Comes up on screen warning recording error any help please guys
Is it ok to give provider Mac code. Also is it better service thanks all
Hi guys any help please. Was fine now no groups loading up have rebooted imputed info. Only thing. Loads is radio group
Think there are 1000s with no problems at all with GTV
Go into features in surfshark. And set it up. What you want to use the vpn for. There
All sorted mate. Had the external player on turned off all good thank you
