Can’t play videos. Says can’t play this video any help please guys
Posts by Den123
‘Some things in life have to change if you want it work do factory reset it will be worth it.
Hi guys says download fail. When try update. All brill now have reset box all good now thank you
Instead of keep asking when is update just keep going on the forum. To see. And check
Sam thank you for updates some people are never grateful please done think we are all the same Sam you do a fantastic job for us all
Mytvonline2 keeps stopping
Try click. U.K. program Sam
We should have market street on GTV
It was on tv Sam
If Google play store is finishing. Where will we get our apps from
Not this Friday. Next Friday
How do you set it to N ONLY in router mate
I would go for z8 pro. For now has the GTV. has had lots of problems. And has still problems
No selling Iptv on this site rules guys
I have had the same as you thought it was just the beta
Bluetooth all working great Sam thank mate
Iam connected to Ethernet Bluetooth all ok now thanks Sam
Hi Sam I had to reset box 3 times to get my Bluetooth to work but all ok now
Epg not populating. Was all good now nothing on 3 lines
Is Netflix still not working guys
All sorted thanks
Can’t get my remote to pair up. Ha reset box WiFi on still not working Sam
GTV box ok. The tv one that express vpn do for the tv. There’s no auto connect
Sony android tv.
2021. Express vpn has no auto connect for android tv so you have to keep logging in every time the tv is switched on rubbis
What is the most popular vpn that our friend use on the forum
Who your vpn mate
This should be for members who come on the forum and post not join then never see them unless they want something free
Have u vpn
Is this real. Has express vpn give 30days free trial anyway
Not on the GTV if you want any app go to Google play store
I would like any formuler box and would be grateful never won anything in my life. Best boxes And best forum you could ask for. Thank you all take care guys number 12 just so I can put it on bedroom to watch
After my CT scan again to check how my cancer is doing
Hdmi cable try another cable
close thread Sam please
How to please
Hi guys is there skip ahead on the GTV. Thanks guys
What would you like to have
