So, despite all the hype, when will this update finally be available?
Info: Next GTV Open Beta 10.0.x
- Miscellaneous
- GTV
pete780 -
June 27, 2021 at 9:34 PM -
Itl be ready when it’s ready….
I was one of the closed beta testers and I standby my initial posts at how good the update was during testing…
Then naturally as it’s opened up to more open beta testing, additional things were found that need to be worked on.
These things happen but there’s a lot of negative comments because the update is delayed.
Would people rather it be released and then have many issues thatl take some time to fix or would they rather wait that extra time for a more stable update?
I’ve been critical in the past but sometimes we all just need a little patience, thought and consideration for the devs that are working on things.
Also consider that not only GTV users want updates quickly but also other users of the z series too, it’s a lot to deal with.
I would hope that all users will be pleased when the update arrives, it’s a huge improvement and massive step forward.
Tomorrow.
So when the update is going to be released?I supposed today Monday
Instead of keep asking when is update just keep going on the forum. To see. And check
hello I have just made the update for the moment ras it solves a lot of concern. Thank you Sam and good luck for the future.
Hi I have just updated my software and it now seems to be not compatible with mytvonline 2 app? I try to open and it says warning please update latest software which I have done but it doesn’t go past this? Has this happened to anyone else?
same here warning
6 of my mates all the same wtf
same here warning
if you figure anything out please let me know!
Display More
so I downloaded this eagerly awaited update to my GTV box and I have not complained once about how long it has taken but it now is not working with mytvonline2 app? Every time I open mytv app it has a warning message to download latest software I click ok and it says all up to date but still doesn’t load and tried rebooting twice and same issue.... PLEASE RESPOND
fixed
I had to restart the box 6 times others took 8 or more then offered me a android update
Settings > Device Prefs. > About > System Update
well well! it's finally here. ..nice to hear, I'll check it out tonight and hopefully not have any issues
