No lie mate just my opinion
Posts by Den123
Go to colour space setting. Click on it ok. You then get a list of all ones you can pick hope this helps
Jo there is a setting you have to do to get all ycb ect. Just can’t think what it was will let you no if I remember
Thank mevi. You right my friend thank you
Hi guys epg was fine now not populating Any help please guys
Same here I thought it was the vpn
Yes please
Tried mobile app still can’t get it to play
Can’t get Netflix to play any help please guys
With surfshark use wireguard. V fast
Surfshark. All the way
Dolby atmos Dolby ect
This GTV is the best
I formatted my wd 1tb. With my GTV no problem here m8
Can you format with RUFUS ON THE GTV ONLY
What WiFi channel would you try Sam
GTV NO BUFFERING AT ALL PERFECT
What router do u use
On the surfshark app there is tunnelling. So you can pick what you want to go through the vpn. Or not
Download. Then 1339 then press red button. Ok
I would wait for Sam to announce it first
Thanks Sam you the best
Best box the GTV. by far
When is beta out Sam
No updates yet
Hi guys. Is it best vpn on router or app
Merry Christmas mate
No black screen here
Hi all is downloader not working as have tried to load won’t load up
Sam you are the best you and mevi. Are the only ones the give fantastic advice. Thank you guys. Merry Christmas
Thank you Sam
hi all what do you think is the best connection. On tv. ARK. or just another hdmi. Socket Thanks
GTV will play atmos
Provider good mate
I no that’s why I will stay with apps
Surfshark app for me
Just set film 1h30min it’s only recorded 15 min set to record from the epg
