Posts by mo2
FW 1.4.22 IPV6 is disabled on the box. But I cant seen to disable it on the router...?
I havent changed any settings prior to or after July update
No VPN, no proxy
Thanks for the reply!
When I exit to the home screen if I attempt to open the market it says no network connection. When I try to go back into mol2 the screen is blank on every channel. Try to reconnect portal and I get an error message..
I can reconnect after removing as Nd reseating LAN cable or rebooting STB
Z8 was working fine/brilliantly with recording and timeshift prior to latest update. LOVED THE BOX
After the update timeshift plays for maybe 20 seconds then loops back to the start, then plays a further 20 seconds before jumping to live and then the audio becomes out of sync. The only way to correct it is to change channel.
If i pause during a recording it wont time shift anymore and ends up ending the recording
These things worked fine for me prior to latest update.
The only thing ive changed is to update.
Using LAN I also have an issue now whereby if i leave mytv app to go to the home screen i lose network connection. If i unplug the LAN cable and reconnect it fixes. Again this wasnt an issue before.
Ive tried a factory data reset and its the same issue.
Any ideas?
