Posts by Mattc
    Hello
    nothing was working.
    so I have reset my internet box and reset factory the Z8.
    My iptv seller send me a new server address in M3u playlist : I have an image 👍
    So I put my vpn .
    it s ok.
    I only have a problem with the epg.
    do you know how I can put Epg ?
    Hello
    I have tried many things with no results :
    - I can see video on YouTube
    - I can download app from google store
    i have restart my Z8.
    I have try a new seller for iptv. Mytv online2 answer the same problem.
    I have try with a code in Atlas Pro.
    Server problem.
    I am using a vpn (CyberGhost) so I try to putt off but same result.
    i look the dns of the Z8 and put google dns .
    I think that my problem is to connect a server . Is it possible than my web provider block my connection ( it Orange in France my provider )
    thanks for helping.
    Hello
    I have a Z8 and everything was ok for many months.
    Since 2-3 weeks : error : your account is blocked or expired. Code 7
    I have contacted my seller . He send me the webpage of his server with my MAC address. Number ok.
    He send me a code for xciptv. : portal, name and password. no connection. Login failed. I have check but all informations are ok.
    I put the informations in mtvo2 : no connection also.
    I have reset my box connection.
    Reset my Z8.
    Change my vpn connection.
    What can I do ?
    Thanks for help
