Posts by vincejog
    Code
    what I mean is that when I made a hard reset, in the configuration I entered my network wifi et ethernet.
    I only had the basic firmware without mytv online. but that it offered me to install it right away.
    except that not even 2 minutes it reboot.
    I then removed the Ethernet to stay in wifi but the same thing.
    then I put the new firmware but same thing reboot fast.
    on the other  when I go wifi and I keep only the Ethernet I have no problem of stability.
    it is clearer ?
    Thank you for your help
    After try a Factory reset i testing with original firmware. Whith this, it is no exist mytv online. But the formuler reboot in 2 mn around.( I remove the ethernet cable) .
    I try with new firmware 1.4.2.2 . Or is the same problem.
    Finally i'm suppose it the material problem ?
    Do you have a new solution or i must do return the formuler in warranty ?
    Thks.
    yes, google translate formuler to formulate !!!
    i try the method yesterday but it is the same problem.
    but i make immediatly the new firmware.
    I must try with firmware 1.2.71?
    the new firmware has a problem?
    sorry if it's difficult to read but i write without google translate:)
    I have a problem with the wifi formulate Z8. so far I used it in ethernet but recently I wanted to put it in wifi. Unfortunately it causes reboots after a few seconds on the home. I tried with different networks, different hdmi cables. I removed all other branchemements (IR ..) but nothing helps. I even tried a hard reset with the procedure to formuler but it continues to reboot.
    is it a hardware problem? I have to send it back as a guarantee?
