I have a problem with the wifi formulate Z8. so far I used it in ethernet but recently I wanted to put it in wifi. Unfortunately it causes reboots after a few seconds on the home. I tried with different networks, different hdmi cables. I removed all other branchemements (IR ..) but nothing helps. I even tried a hard reset with the procedure to formuler but it continues to reboot.
is it a hardware problem? I have to send it back as a guarantee?
Thank you for your help
reboot when i use the wifi
yes, google translate formuler to formulate !!!
i try the method yesterday but it is the same problem.
but i make immediatly the new firmware.
I must try with firmware 1.2.71?
the new firmware has a problem?
sorry if it's difficult to read but i write without google translate:)
Yes, install newest update first, check, if problem exist do factory reset.
Do you unplug or turn off your AC power after using Z8?
After try a Factory reset i testing with original firmware. Whith this, it is no exist mytv online. But the formuler reboot in 2 mn around.( I remove the ethernet cable) .
I try with new firmware 1.4.2.2 . Or is the same problem.
Finally i'm suppose it the material problem ?
Do you have a new solution or i must do return the formuler in warranty ?
Thks.
It is really hard to understand what you exactly trying to tell us. If i understand well, you installed newest firmware and mytvonline is not included anymore? Go to "Market" and install from there MYTVOnline 7.2.2 again. Could you tell us what happens or which app is active when the box reboot?
Code
what I mean is that when I made a hard reset, in the configuration I entered my network wifi et ethernet. I only had the basic firmware without mytv online. but that it offered me to install it right away. except that not even 2 minutes it reboot. I then removed the Ethernet to stay in wifi but the same thing. then I put the new firmware but same thing reboot fast. on the other when I go wifi and I keep only the Ethernet I have no problem of stability. it is clearer ? Thank you for your help
Can you check Settings -> IPV6 -> is this off or on? Turn off, if on.
It is very strange that the box reboots if Wifi is in use. Is your box connected with 2.4Ghz or 5G with your router?
Iptv is off,
i'm testing with 2.4 ghz and 5ghz.
i'm testing with 2.4 ghz and 5ghz mobile network.
same problems ...
Ok, contact your seller for warranty, maybe is your wifi modul really damaged.
