Hi , I would like to know if real dedrid can run on the z8 box apps if it can Please please tell or show how
Posts by donboy
I am new to this so how do i run real debrid on my z8 box for mytvone 2 app. I am so lost
Hi thanks for your reply please can you tell me what i need to do to have real debrid running on my z8 to help the buffering
please can you give more info on this debrid , will it be good fore the z8 box as i get lots of buffering
having same problem , when i connect works fine when i change channel all epg working fine VOD comes up but all i get is a black screen
please can you tell me to switch from mac login to api (line) login my box turns off after 3 hours
hi , I have spoke with my provider he says the NO time limit on playback, I am all up to date on updates , in settings it says 3 hour play limit and it cant be changed , I have a old X3 pro box , set that up never shut down at all , this needs sorting asap , having to click ok every 3 hours not good or if you miss it have to turn on box again
hi please can anyone tell me a good air mouse to use with the z8 box
thanks AB for the reply , I am in Russia working , internet here is hit and miss , on speed test shows 95mbps speed , but still getting buffering jerky , I will give VPN a good what the 1 to use you think
is it worth running a VPN on the z8 box , do it make the internet faster slower stable
I am on the latest beta , so i cant upgrade to the latest official release , if i am on beta , i have to stay on that right
hi I am using Ethernet cable from my ASUS router , It happens on all of them even SD .I have the latest BETA installed ,I have tried all the things I have read on here ,
I have the same problem ,dont matter what channel I am on live tv always jerky spluttering sometimes buffering , My provider saying it the MYtV 2 APP , My internet speed is showing 93MBPS download and 95 MBPS upload , I am connected via Ethernet cable straight from AsUS RT-AC68U router
