Ethernet connection issue (spec. UK)
  • My brother has constant problems with stream blacking out in Thailand on Z8..he’s afraid to change channels once he has a working stream. He stopped using vpn because speed dropped from 600 to around 20. When everything stops working he says rebooting router gets live tv back. I was just wondering if toggling on/off ipv6 might help? It also could be that the Thai internet where he lives is just really unreliable. Any fix suggestions I could clue him in on would be great.
    try to turn off ipv6 on the router and the z8 and try again
  • Hi, I'm having massive problems and my provider is adamant the problem is my end. Using Formuler 8 with My TV online 2. I'm just getting a black screen but accurate text/channels. My provider insists I need a VPN modem, but i think he's wrong. I use Nord VPN, I've tried every setting I know, reset router, reset box, changed VPN etc. but I still have black screen (no channels work). I'm with BT and I'm thinking this may be the issue?
    That being said, I've used my phones 4G and still nothing. I've only had this service for 3 weeks and it's continually playing up. BUT my friend has been using the same provider for 5 years and had no issues. Is it BT Hub?
    PLEASE, any help greatly appreciated!!!
    MANY thanks!!!
    Boof
