Posts by gambera
    With this method, you’re purchasing an m3u subscription from your reseller and not a m*g subscription correct? Also the username and password are the same that my provider gives me?
    Sorry for the late response. There will be two separate subs, one from your provider/reseller and one from xtream editor (to use their services).
    Xtream editor considers formuler as m*g device for some reason but it's not an actual m*g box.
    Do you currently have any iptv provider sub?
    The only reason I use xtream is because I can rearange the channels the way I like and not for their epg service.
    Mind you, xtream asks 19 swiss franks/year for use of the playist editor. Using m*g device is an addition 5/y, if I remember correctly.
    Sorry to hear the USB tuner not completing its scan even though you let it cool off. I was shocked at how much hotter the Geniatech got compared to the Hauppauge. I'm assuming you've tried resetting your box and making sure the antenna hasn't been moved since the last time you scanned?
    Antenna has not been moved, but I'll try resetting the box later today.
    I forgot to mention that I have Formuler Z8, not Z7. Just FYI.
    Received and tested the Geniatech A681 USB ATSC tuner and it doesn't seem to perform as well as the Hauppauge 955Q USB ATSC tuner. There are some channels that appear to be choppy on the Geniatech but smooth on the Hauppauge. The Geniatech is a smaller unit and fells like it gets hotter than the Hauppauge as well. I'll be sticking with the Hauppauge and may keep the Geniatech as a backup. The only advantage the Geniatech has is the price. It was less than half the cost of the Hauppage on eBay.
    I see I'm not the only one with heat issues. I have the Geniatech and it gets hot to the touch.
    It was working well until today. I rescaned, or tried to and it won't go over 48%, it's just stuck there.
    I'll unplug it and let it cool down and try again.
    But the heating issue bothers me because the USB port gets hot as well.
    BTW, is there telegram channel for quick chat?
