Maybe xtream-editor wants all MOL2 users to abandon m3u and API lines and pay for their M*g device option.
Xtream-Editor subscribers & MOL2
Cob -
July 30, 2019 at 10:41 AM -
Everything has over Months works.
Since yesterday suddenly only a black picture.
I am connected in MOL2 via M3U playlist with data from Xtream Editor.
And I can have just 1 M*G line...right ? :///
Yes
Hopefully XE fix the problem soon.
I wonder if the issue exists on the Z7 range too.
well, maybe its not a problem with Xe as the api lines work in tivimate when I tried earlier today.
What to do when my list has an EPG for a channel .... XE doesn't have it, how can I keep an EPG?
It can not be a coincidence that it will not work in MOL2 and that Xtream Editor will be releasing his own X3M Player / Xtream Editor Player at the same time.
yes, this entire debacle comes across as being somewhat suspicious. When I sent a suport ticket to xtream-editor they told me to use this new X3M player and then they went silent.
I doubt that has anything to do with it. X3M Player is a free companion app for XE subscribers. It makes no difference to them which app you use as you've already paid your subscription.
In fact it's in XE's best interests to allow their service to work on as many different apps as possible. Hence why I believe they will fix this problem in a reasonable time.
Working for me, connected via XE m3u link.
Do u have Catch up ch. ?
No. I don't use catchup.
Do not understand why it supposedly works for you and still does not work for me.
The XE M3U Link works for me on other players but not in MyTVOnline2.
I've bought an extra XE subscription so I can create a favorites list and sort them as I like,
while keeping the comfort of MyTVOnline2. Unfortunately, do not bring me anything anymore. Disgusting.
No, it's definately still not working with MOL2, except for a M*G line, but working okay in tivimate.
not work
not work
on tivimate? Cuz, yeah....xtream-editor was working on tivimate the past few hours and now poof it stopped, just like that.
Working here ok in Tivimate.
oh yeah....must be something on my end then...thanks!
Anyone know if I can have multiple M*Gs in Xtream-Editor and if they charge per M*G line or is it a one time fee?
You can have multiple m*g lines, but they charge per m*g line. Also you can only have 1 m*g line per mac address.
Things are ****ed.
You can have multiple but they charge every magg line you add and I think it's a one time fee for every magg line. This is for the standard edition as I know.
I get this from XE..
I can not. We have not changed anything here. Please create a new connection and pay attention to typing errors.
Hello guys,
also had contact with the support of XE.
Please delete your M3U playlist in MOL2 and create it again completely. Just like before.
I did not have a typo in my playlist but since the weekend the playlist did not work anymore. For whatever reason.
But as I said once completely deleted and re-created and I can connect again via MOL2 with the XE M3U!
Hello guys,
Awesome! I'll try that again.
But I did that on Monday and it made no difference.
Hello guys,
U refer to m3u lists AND API lines, or just m3u list?
I have deleted both my API line, m3u list, re-entered it into xtream-editor and there is no change...they do not connect in MOL2.
But, I will try it all over again.
Thanks for your input Cob.
Ok everything has now started working again by itself.
I did not have to re-enter the Api or m3u details. The old details have just started working again.
Yes, it has started working now....strange but good.
Been reading the whole thread. Has any of you tried removing the secure server from the XE's m3u file?
It's never worked for me, even today, if I try https, I get blank screen.
So, I always use the link w/o secure server.
Works with both http and https here
Can anyone explain the difference between the XE M3U list and the XE API line?
Catch up not work :))))
Api is for people with an Xtream Codes m3u (http://server.extension:8080/get.php?userna…_plus&output=ts). It allows XE to draw much more detailed information ie - better epg integration, catch-up, IMDB for VOD. XE's m*g lines can only be set up if it has access to the Api too.
Basically the XE m3u line is only really used for users with an actual .m3u file.
i tried with merged line i added 2 lines that are merged into one ... the chanals from the first line works the chanals from the second not just black screen .... but the epg works
somebody know what is wrong ? -
I've subscribed to XE Editor and setup my portal as an API within MOL2 - connects fine, but I have two issues
1. Catch up is not working, but I do receive the little red icon within the EPG for the past 3 days. When I select it says 'error cant play this video, please try again later' Is this because of MOL2?
2. the EPG is not updating with my chnl changes (I have force synced)
Any ideas? Thanks.
Any ideas? Thanks.
Are you using the m3u or m@g line?
Catch-up works via m@g but not with m3u (MOL2 issue). EPG should work for both.
Not m@g, I setup with Xtreme Codes Api (short XC) with login as per the article
I've managed to connect via my playlist, so my updated groups are now working as intended. I have now got the EPG data to download, but I now have no catchup option (it is no longer showing)
Any ideas?
I am unable to record and watch another chnl too (this a limitation of MOL2?) I have 2 connections.
Steps taken so far
Created API line in XE, created playlist within MOL2 connection utilising the API line details created, connects fine and EPG updating. Just the issue with catchup and recording limitations
Display More
Any ideas?
Steps taken so far
Recording one channel and watching another isn't available yet. Is apparently being worked on for the next update (I need this too).
Catch-up doesn't work via XE on the standard line yet. In order to get catch-up to play in MOL2 via XE you have to set up an XE M@g line. Yeah it's costs an extra 2.50 Swiss francs, but it actually works very well (you use the mac ID listed inside the MOL2 app and not the actual boxes mac address).
It's all a pain in the arse, but it's a very usable workaround.
Just after a little bit of advice please now i've read the forums. Just to recap, what are the benefits between the following three again?
M*G
XC API
M3U
Which would be the best option to use with XE editor and for catchup to also work - I think it's M*G, but just wondering how everyone else has theirs configured.
I don't think it's possible to record one chnl and watch another at present.
