Yes it’s ok and works with other STBs
Unfortunately the tuner is broken down
and Should have replaced
Thanks all
Thanks all
Tnx
using DiSEqC motor i did even reset to the factory default and recovery mod but no solution it’s a little hot and un normal behind tuner and BNC maybe hardware problem !
this is new box and i opened it for the first time in costumers home
anyway thanks for your response
Hi after scanning some channels and updating the s turbo pro the box rebooted and not started in normal way
when I disconnect the cable from tuner it starte and boot could someone help ?
But i got the pro version for my friend and updated it through the default server easily no problem
