Think there are 1000s with no problems at all with GTV
In what way will that help all of us that have problems?
So your answer to how I can make my TV do the upscaling instead of the GTV box is to use another TV and another box? Thank you, very helpful. ![]()
In settings of the gtv, put 1080 instead of 2160.
That will "pass through" channels with 1080 but will still upscale for lower resolution channels and downscale(?) for 4k channels.
Can I somehow configure the GTV box to simply pass-through the received resolution and let my 8K TV do the upscaling?
No matter what I do, my TV reports incoming 4K signal even though the received channel is far from 4K.
Yes, I agree, but I fully understand the Logitech decision. I mean - when you have a unique product that is the best of its kind, what option do you have other than discontinue the production?? ![]()
I have a Z8Pro, a GTV and a Harmony remote.
When using the native remotes, each remote only controls the appropriate device. When the Harmony remote acts as a Z8Pro it only controls Z8Pro, but when Harmony acts as a GTV remote it controls both devices at the same time.
Is there any way I can avoid that and have Harmony controlling only the selected device?
Occasionally after a wake-up (from standby) I get a black screen. EPG can be displayed but EPG updates are extremely slow (if any). Change of channel does not do anything, still a black screen.
Restart of MOL2 makes the current channel to be displayed, but EPG updates are still sluggish as is channel change (several seconds before any reaction when changing channel).
A reboot of the device solves the problem.
The top row of apps on the GTV start screen I guess is called "favorites" in English. There is a button to add a new app to this selection, but how do I remove an app from the list?
Support ticket created.
Yesterday I got some software updates to my Z8 box (v1.4.60) and after that I experience repeated crashes in MOL2, normally when using the EPG page. All of a sudden MOL just dies and I'm back to the Z8 start page. Sometimes I get a popup message saying that MOL2 died, sometimes I only get the start page without any popup. ![]()
It works OK with Smart IPTV.
QuoteWhy no answer to the question from Mevi ?
I'm not the one that started the thread, but I have the same problem. I have no other device to test with.
Any news on this issue? I also have the problem with missing letters in the EPG.
Is there any way to get usable subtitles when watching 3D movies? Subtitles are displayed as if there is a 2D movie which makes them completely unusable in 3D.
