the letters work in the description but not in the actual titles. Any ideas please?
Scandinavian characters/letters do not work in EPG titles
Pelle -
May 21, 2019 at 9:09 PM -
Can you post a picture? I'm also from Scandinavia and I don't have this issue.
First, apologies for the late reply! Attached to this post is a picture where 'å' and 'ä' are missing in the title.
I'm 99,9% certain I had it working earlier. It's during the last couple of weeks things took a turn for the worse.
Yours is working, now how does our setup differ?
And yes, I have the missing letters syndrome also in my EPG menu.
Did you check on another device/app?
Any news on this issue? I also have the problem with missing letters in the EPG.
Why no answer to the question from Mevi ?
Quote
I'm not the one that started the thread, but I have the same problem. I have no other device to test with.
Can you test with other app on same device? stbemu, vlc, smart iptv, etc...
It works OK with Smart IPTV.
Smart iptv app has it's own epg data.
Mevi is right
Try with Tivimate app to compare, but i think you just got Provider with not good epg database. There are some known not using UTF8 chars, result is such words are missing in channel description but included in detailed epg. This would work normal if the Provider change the setting UTF8 to default. This is not Box issue, it is Provider issue.
