hi, i download it install it, but when i start it, it close promptly .can help me everyone. thanks
Posts by maestro
Nothing work, reset box config new install new dazn, ne left right. up down ok but left right nothing see max. 4 all right nothing. and to start a cl game i take the mouse other nothing work.
but now I do not care more.
send box retour after 12 days only problem with this z8 box says me its a shit product never buy. bye bye formular
Hi, i have there raw, but the sound is bad. rear box from 5.1 not loud, same move on dreambox mediacenter or firetv plex client much better. so the problem is the z8
when i start the mkv file direkt over browser from z8 i hear nice DTS/DD 5.1 Sound. When i start same Video over Plex Player sound is bad. its an 7.1 track when i change on 2.0 only front thats ok, but unter 7.1 the rear box a very quiet dont hear realy. when i start same video on fire tv stick with same sound optionen its 100% better.
also unter mytv app from z8 and from dreambox normal live tv movie, dreambox nice sound z8 is better as in plex but not realy top.
first box i test where i have so much problems
4month later no netflix in appstore, you can load in over marketplace or how this standard app named.
there is netflix with an older version but its works.
hi
verweise auf links:
Zurück-Taste/ Sprache/ Favoriten
Current status and overview - Z8 Launcher and MOL2
Februar 2019
Missing Features:
- Edit app order/position - noch immer nicht eingeführt
- Simple weather widget - keine ahnung ist mir egal
- Backup/Restore user partition - weiß ich nicht
- Remote provisioning - ??
- AndroidTV Remote service - nicht eingeführt
- Mount Network (NAS) drive - muss mich jedesmal neu verbinden und aufnehmen darauf geht auch nicht nur auf lokale usb hdd
- Screensaver - für mich unwichtig
- STB WebIF -
- Change screenshot path
- channel list sorting fehlt noch extrem wichtig
- multilanguage auch noch immer nicht.
da frage ich mich kommt hier noch etwas oder soll ich die box gleich wieder zurückgeben, 10 tage habe ich noch. aber sieht eher so aus das die weiterentwicklung nur sehr langsam wenn überhaupt weiter geht.
lg
Hi hab das das selbe Problem, nicht unbedingt das es nicht geht aber die qualität in plex ist schlecht. habe plex am amazon fire tv4k stick dort ist der ton um einige sbesser was das 5.1 betrifft, helikopter kreist durch alle boxen, bei der z8 hingegen hört man die hinteren boxen oft nur minimal hier fehlt das 5.1 feeling
liegt aber zu 100% an der z8 weil wie gesagt im amazon firetv stick funktionierts um einiges besser.
app ist die selber und einstellungen ebenfalls gleich.
