I have the same problem.
Posts by Yga
It is not a real app from Formuler you found in google as a tagplay store, it is someone who copied the logo to MyTvOnline2.
You use the URL and Username and Password from your m3u link.
It sounds like a stupid explanation from your provider. Hope you find a better supplier. / Yga from Sweden
Z Alpha is slightly cheaper and it has Mol2 just like Z8.
Personally, I think you get more for your money if you choose a Z8.
The Z8 is the best, it's the one to choose.
tvman, thank you for announcing that it works for you. I have received confirmation that it works for some but also that it does not work. It's not a big problem but it could still be interesting to find out the reason why it is the way it is.
I also tried this but there was no change.
Soppdk is right.
The Traler function disappears if I select certain Menu Languages in Mol2
If I select: - Settings - Swedish as Menu Language, the Trailer-function is gone.
I have tried ALL languages and only when I select English, French and Lituviu as Menu Language can I get the Trailer function.
DRM is something installed in the update or something we have to install ourselves after the update?
For those who do not know, what is DRM and what does this feature do?
Mytvonline2
- settings,
- turn off Auto Frame Rate (AFR)
if enabled.
Want to have too 😃
Give them ID numbers and it will be right.
Should you have the box just to watch iptv, ZAlpha works great. It uses the app mol2 just like the Z8 and you won't notice any difference. The Z8 has better specifications and has a slightly higher price. Personally, I think a choice of Z8 is better.
Z8 is best, choose it.
It will be in the next update
You're probably not wrong.
It is your IPTV provider that controls how many channels have this feature.
Contact your IPTV provider and ask if they are planning multiple channels with this feature.
I also use the Z8 and would like a combined box for Satellite and IPTV.
Does SAM know if there is a new box that has MOL2?
The information in your favorite list is probably related to your subscription from your IPTV provider. You can delete your channels in your favorite list the same way you got them. (with the blue button)
MOL2 - VOD & Series.
History- It can be good with history
BUT it should be possible to clear and hide the history.
The history list will be overflowing with VOD movies and you will only get annoyed at it.
I'm not interested in seeing what series my wife is watching and my kids don't have to see what their parents are watching.
The history feature was not good.
Yes and no.
With the answer in hand, the answer is simple.
The problem is NOT in your Z8 so stop looking for something wrong in your box. The one who can adjust and correct this is your IPTV provider.
Contact your iptv provider and ask about this.
The problem is that:
The problem occurred with the XC fiasco. After xc has disappeared, your iptv provider has broken links to your cover images and must fix them for them to work again.
Note If you have a Z8 with working cover images, it is because you did NOT clear MOL2 cache data in it.
If you clear cache data in your Z8 with working cover images, many of your cover images will disappear and will not be restored unless your IPTV provider fixes this.
Again, contact your IPTV provider and ask if they can fix this.
(if many ask maybe it will go faster)
SAM, Now you may have been right, despite everything. It could have something to do with the xc fiasco. I would like to test something if you have an idea of what to find.
I would like to believe that you have the right SAM but unfortunately what you describe does not work.
Today I have tried a new Z8, (a third box) it becomes like my box 2, all pictures are not visible but in my first Z8 it works.
I called a friend who has two Z8 with the same iptv provider that I have and he also has problems with one of his Z8 showing all pictures but not the other.
It seems to be the same there, the oldest box works and shows all the pictures but not the newer one.
Factory reset has also been tested with no positive results.
I have the same problem and have taken it in another thread but want to come back with this.
(I've really tested everything).
I have 2 Formuler Z8, one shows all pictures while the other does NOT.
I have tried different iptv providers and get the same result.
I have tested via Portals and m3u via Playlists but this is just one of my Z8 that shows all VOD images.
The Z8 showing all pictures was purchased just when the Z8 was launched and has been through all the updates.
My second Z8 that does not show pictures is purchased in October.
What I believe is that the error is somewhere in the Z8 and in any update that my latest Z8 has not received.
I would like to say that the error is NOT with the iptv provider.
(But I could be wrong)
It would be very nice to have a solution to this question.
Thanks to ddd and SAM for suggestions for solving this. I use cable in to Z8, no wifi and no firewall. Oddly, I'm new here and happened to clear my last post by mistake. I will return when / if I find the solution to this problem.
I think I tested it with but how is the best way to do it?
Yes, it is in the MYTVonline2 app this happens and both of these Z8 have latest firmware and MOL2 version. How strange is that? I do not understand this.
Both have the same connection and with the same IPTV provider. Both are installers in the same way. The first box is a purchase when the Z8 came out on the market, the second I bought for a month ago.
Hi!
I have problems with my Z8 not displaying all cover images in VOD and Series. I have two Z8's, and I use the same IP provider.
My first Z8 shows ALL cover images but the second only shows some, almost no cover images.
Is this a setting you can do?
Or any file you need to download?
