I was never able to get the stick working..forgot I had a 2TB external HD that I wasn't using so I just hooked that up and now we are good
Posts by joshthomas40
I tried this and it just opens disney+ and then it crashes .. has anyone found another way?
I highly recommend NTFS. Since I use that recording (and viewing recordings) is a lot more stable.
However the filesystem type will most likely not make any difference with the "disconnect issue". That is more likely to be related to some Android APM/ACPI "feature".
Hmm alrighty .. it's formatted right now on NTFS so I guess i got unlucky and chose the wrong stick to use .. least I have a backup stick now
Ok I will try, is there a Rufus equivalent for a mac? I use m3u as my connection for iptv
Should I try a fat32 format instead?
Mine is there as well...recording is not the issue, I can record, the issue is if I leave the box idle (ex over night) the stick will disconnect
Update;
Reformatted the usb stick last night and still had the same problem...usb stick disconnected again. I'm at a loss now no idea what to do
I will try another stick. I've reformatted the usb to NTFS at the advice of someone on telegram, see if that works
The stick works and is recognized by the box, I can record to it just for some reason if it sits idle too long itll disconnect
I have newest update (not the beta one that was just released) and newest version of MOL2
So I bought a z8 last wk and bought a Verbatim Pin Stripe 128gb usb stick for recording. My problem is that if the box sits idle for too long then the usb disconnects and I have to unplug and replug it back in to get it working again. The device works on the box as I have recorded things onto it, problem is over night things won't get recorded because the usb stick disconnects. I have tried both usb ports on the z8
