Posts by Lee
    Hi Jennie,
    Recording Problem was before this update!
    I was able before to record a channel and at the same time watch some VOD's or Series on same portal. -)) don't know how but it worked when I mentioned this in one of my posts here right after thr last update and they mentioned that this was a bug and they intentionally stopped this function.
    So am able to record but not watching something else on the same portal " record warning" comes up but that's not my problem right now.
    New problem watching VOD's arised right after the last update 28.07.
    When I select VOD's they are loading and I can select one of them including title info but there is no more watch option. Just check out my last post with picture there should be an option to select play or watch its not there anymore.
    I am using a second provider as backup and same problem on that as well so it definitely has to do with the latest update. But only on VOD's not Series.
    During this last update I realized that my box needed two attempts to download and install the new update.
    Yes I am using "username and password" information to log in to portal and no problem with m3u line. I have tested it already.
    Kind regards,
    Lee
    Hi Lee,
    can you provide photos of the issues?
    HI Jennie,
    Thanks for your response!
    Don't know what connection I use?! I used my data for Portal and m3u line and it worked very well till now. I still have access when I'm logged in via m3u line but portal ability to watch my movies isn't working anymore simply "watch" option isn't there anymore.
    It's working on my spare box z7+ but not on this one.
    They should tell us if major changes are implemented and not just gone!
    On the last update I have lost the capacity to record a channel and watch a movie or series. When I complaint they told me that this function was a bug maybe a nice bug but it was helpful this time after update I lost watching movie capability.
    Don't know what to say.
    Kind regards,
    Lee
    Hi Team,
    Don't get why after an update the Box isn't working like before? Just updated my box today like on the last update some functions went missing and this time VOD's are gone!? They seem to load but there is no watch option anymore just the title is present nothing else. Series seems to work fine but the build in player is not able to download any subtitles.
    Again I regret having updated my box:-((((
    Kind regards,
    Lee
    Hi together,
    Just updated my Z8 yesterday and found out that I'm no longer able to watch any Series or VOD while Recording a regular Channel!
    It says"warning - recording" and I'm not able to change to VOD's or Series.
    This was possible on the version before the last update.
    Could you confirm this issue?
    Actually this function was very valuable for me.
    Best Regards,
    Lee
    Thanks a lot for your responses. That keeps me away from trieng again and again. My guess actually was, that something isn't right with my hardware!
    Because my MAG351 is able to support 2 devices.
    SPDIF might be the best source not to keep tv busy for others.
    Thanks,
    Lee
    I'm new here. How many Bluetooth headphones can I use simultaneously? I tried two devices but one of them is always silent?
    I use another box MAG351 and this box is capable of two devices would be great if this works on this box as well.
    Bluetooth on my Z8 is not as stable as on z7+ seems that reconnection is always a problem I need to pair everytime to reconnect.
    Kind regards,
    Lee
    Hi together,
    Does Z8 support two headset devices Bluetooth at the same time?
    I have experienced issues and one headset only is working the other is connected but no sound.
    Thanks,
