Do both firmware and MOL2 need to be updated? If so go to the Market and update MOL2 only first. Then after MOL2 has been updated update the firmware via software update. Had this happen to me and this was the work around.
Posts by Sally15
Is this a provider custom firmware? If so to remove it but be warned this will reset the box to default, you will lose all settings including provider information.
Go to home menu - system info. If a block installed you should see menu entry "Check for configuration update". Highlight the configuration line, then press 0 (Zero) -x10 times -> It will factory reset and unblock the entire device.
MOL2 crashed to home screen. Repeated a second time. Came back fine after scend crash. Logs sent 000000121FE7C
The Z10 does have a port for the IR extender. It's on the back of the unit opposite side to power port. Did you not receive an IR extender with the unit?
For instructions see the link in Sam's last post in this thread Can't add portal - Formuler Z10 Pro Max, Z10 Pro, Z10, Z10SE - Formuler-Support Forum (English). Note you WILL no longer have the provider
Thanks for the response. Will keep a look out when it happens next. Will check to see if anything has been updated in the background.
MOL2 is still crashing. Watching live TV the unit will go to home screen then MOL2 will restart, hang with a gray screen for a few seconds then go back to live TV. This can happen 1, 2 or 3 times in a row. Logs sent C11A54. Firmware is 10.10.41 MOL2 is 10.10.44
Tried to do the update on my formuler 10 SE,gît the error: not enough memory, so I cleaned cache ans get rid of all the programs that I could delete. Result: not enough memory, how can I proceed now please?
I had the same issue. Install MOL only via the market first. After MOL is installed then try installing firmware upgrade through software update. Worked for me.
As for the units either the Z8 Pro or the Z10 series. You will be happy with either one. Both use MOL2. Also note I have both types and they work fine. I happy with either.
Z8 Pro is an older unit which the software has been refined. It more or less has all the bugs worked out. It also runs Android 7.
Z10 series is a fairly new unit. It runs a version of Android 10. It also has newer hardware. Being such a new unit it has some bugs, but given time to work out the bugs it will be fine.
As to discussing which service subscription to use is against forum rules. The best advice I can give is to try some free trials and find the one you like.
yes, first I turn off the device, then I disconnect the power, after the power connection, the device turns on, the screen comes up, after 1 second, the message is turned off and the device goes to sleep, I turn the device on again from the power button
Why are you disconnecting the power? This would be normal operation when power has been disconnected. Leave the power plugged in and it should work fine
tip: dont use standby functions. after watching, just do a full shutdown. Then u never get this problem again.... a fresh cold boot every 24hrs keeps the z10 working like new
Thanks for posting the tip. This might help others.
I have always used full shutdown myself. BTW this was also also on a 60fps channel
go to home/market/installed apps/swupdate App, Uninstall the app the reinstall the swupdate app. Then search for FW/MOL2 update
Have you tried another app such as TiviMate? Does it happen in both or MOL2 only?
Another thought. Have you tried reinstalling IPVanish?
If you have upgraded from android 7 to version 10, I would say to do a factory reset.
How is this going to be hooked up in your cinema room, ethernet or wifi? If you are going ethernet then the Neo's ethernet is going to be fine.
If you use wifi then distance and walls may and I say may cause issues. Buffering and lose of signal. The Z8 would be better as it has 2G and 5G while the Neo only has 2G wifi.
- None of my m3u list works on MOL2. No VOD or TV
- They all works fine on other appliacations.
- It's loading up blank for me. I've restarted. Cleared cache and re-added url nothing work so far.
Try reinstalling MOL2.
Original GTV Android 9.
GTV now at Android 10. Updated in 2021.
Unit probably being shipped with Android 10 update already installed. Which equals marketing
Check Home-Launcher Setting.
See if it set to start
It wasn't a provider issue. Another box, different manufacturer was working fine.
Hi Sam,
The submitted log number was 8BF278. How do I create a ticket?
All channels went to a black screen while watching live TV.
Restarting the box did not solve the issue. Had to unplug box for approximately 10 minutes then the box worked perfectly.
Got mine from dreamlink.ca
