Posts by furious2004
Hi, check your wifi modem settings to see if the 2 bands are separate 2.4ghz and 5ghz, try to connect to the 5ghz it is the fastest frequency
hi, try connecting it via ethernet cable to see if it works, otherwise do a factory reset and try again with your wifi to test
Happy New Year 2025 to everyone and above all good health
So frustrating wasting money to buy new z11 pro and it's so buggy, who has time to read hundreds of blogs and troubleshoot. This should be recalled. z10 with mytv2 was the best. Mytv3 has been a nightmare
I personally have the Formuler Z11 Pro Max, there were just a few bugs at the beginning but with the updates everything is fine now, mol3 is awesome, in fact 2 months ago I sold my Z10 to get a second Z11 Pro Max. mol 3 is just great
you don't see your supplier if you have placed 2x the same VOD/SERIE from 2 different suppliers in Favorites.
Idem when you look in HISTORY
yes in the favorites we don't see it, but before putting it in the favorites, you will look for the film or the series in the chosen directory or at the bottom right it is marked the suppliers, so just look before put it in favorites
NO!
You should read correctly...this happens indeed in the categories in the "submenu" EXCEPT IN "FAVORITE" and in "HISTORY"
A subcategory can only be from 1 provider at a time, but in Favorite and History, the VOD and series ze mixed from 2 providers, and there is no way to see which one comes from what provider.
strange, because I see my supplier displayed when I go to a subcategory, as I have 4 suppliers when I go to a category, it marks me at the bottom right the name of the supplier like that I see on which server am I on if I select the film or series
When we have 2 or more iptv suppliers, In Favorite and History, it is not possible for now to differenciate 2 identical series from 2 different suppliers:
there is no indication of the supplier. Please, could you put a mark stating from wich supplier the serie or vod is ?
hello, when you go to the submenu in the vod, when you go above it is marked at the bottom right on which server it is located...
happy new year 2024 and above all good health to all
I purchased the formular X88 pro 13 ultra HD 8K. However, I can't find information on the configurations for installing apps and streaming stations, can you help me?
hello, in my opinion you had not read the brand of the case you bought, your case is not a formulated case
This a known issue with the BT1 see my post here on the forum to. Only thing you can do best is to put the Formuler box in standby and it keep go working. When you shutdown the box or start over the problems will start again, sometimes the remote is pairing/unpair etc over and over again. Problem with the firmware i guess.
personally I have the formulated z11 pro max case and I have no problem with the BT1 remote control, it never disconnects
Display More
Bonjour à tous, tout d'abord merci de m'avoir permis de rejoindre votre groupe. J'ai récemment acheté le Z11 Pro Max pour remplacer un stick A***n 4K et je dois dire que je suis ravi du ProMax11, une machine vraiment sympa et bien meilleure que mon ancien stick.
Cependant, j'ai des problèmes pour connecter ma télécommande BT1 au Z11 Pro Max. J'ai mis le Pro Max en mode ajout d'accessoires et j'appuie simultanément sur les touches Menu et ok et la télécommande ne clignote pas en blanc, j'ai essayé d'appuyer sur la touche menu juste avant la touche ok et inversement et toujours rien. Le seul voyant que j'obtiens est un voyant orange lorsque j'appuie d'abord sur la touche Menu mais s'éteint dès que j'appuie sur la touche ok. J'ai essayé de nouvelles piles et téléchargé l'application Formuler Remote qui m'indique simplement que la télécommande n'est pas connectée,
La télécommande fonctionne sur le Pro Max pour les actions normales à distance, mais ne passe tout simplement pas en mode couplage. Selon l'application, ma télécommande est déconnectée, je ne parviens donc pas à déterminer quel est le micrologiciel actuel de la télécommande.
J'ai testé la fonction Bluetooth sur le Pro Max en connectant avec succès une paire d'écouteurs sans aucun problème.
J'apprécierais vraiment toute aide que vous pourriez suggérer, car je dis que je suis ravi du Z11 Pro Max et que je l'ai configuré avec tout ce que j'avais sur mon ancienne clé et plus encore.
Dave
hello, you go to add accessory in the bluethoot menu, when the box and in search mode you press the "ok" and "menu" button at the same time and stay press it until the formula screen indicates associated device
Beta is tested by 10 users.
almost all says its fixed, (see post sam)
So very soon comes the update.
Thanks for the info, more than waiting then lol
Almost all Beta testers reported good feedback in this private beta and no roll backs. My report to Formuler will follow tomorrow and Formuler will decide how fast the fix goes ota and available for all. Please await next update and install.
hello, will there be an update for this problem?? because my z11 pro max I have the same concern too
yes I know you had already contacted me lol, when it did to me I forgot to send the report, because I got angry and I removed the z10 pro max to put my z8 pro which with it I I've never had a problem :-/, I'm going to put my z10 back and when it still gives me the problem then I'll send the report, it's only been doing this for 3 months, before it's going great GOOD.
did you try with ethernet cable instead of wifi?
There was a case that caused this because of bad internet speed quality; increasing the mol buffer to 10seconds helped.
try and see if it would make any difference in your case.
hello, if you are answering me, I tested with wifi and ethernet and I have the same problem on both ways of connecting
Display More
Ok, please let us stay in line to find fast the reason for this, we understand that this doesn`t happen on Z11 but only on your Z10. You also excludes the 4 different providers and protocol, ok let us see where this lead if your neighbour on two same subs doesn`t have same issues. This shows then only on your box.
Please do following, even if you tried already:
1. First check your Firmware and SW to see if last update installed.
2. Go to Settings -> Apps -> Mytvonline 2 and delete cache and data. Reboot the box, disconnect all optional devices from the box and test again.
if this doesn`t help.
3. First disconnect all USB and SD card devices from the box, keyboards etc. too.
Factory reset the box like in this video and make fresh install ->
External Content www.youtube.comContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy.Try again with only one subscription and report again.
hello, I've already tested everything you suggest, but it's always the same, the factory reset with the paperclip I did it twice, and twice the reset via the menu, I even uninstalled mol 2 and reinstall it but nothing done, so I really don't know what to do anymore, and the box is up to date
Try another provider...
I will be surprised that it will come from the supplier, 4 suppliers who are the best servers that can be found in my country who will all have the same problems is only on my z10 pro max while my neighbor has the z10 pro max and there he is also on 2 of my suppliers and he has no problem
Which protocol do you use (Stalker, XC Api, M3U) and do you have tested other protocol and new connect with your provider? Please test.
The FW and SW is up to date?
I use 2 servers in xc api and 2 others in stalker, and the same servers are also on my z11 pro max and my z11 never returns to the home menu
here I guess I have to repeat my question again lol, because I don't understand English too much and the translators are sometimes not that great
so here is my problem
hello everyone, I have my formulate z10 pro max which is funny, when I watch TV it often goes back to the home page, so every time I have to restart mol 2, I have already done so at least 6 factory reset, in the menu and with the paperclip in the ir socket, do you have an idea because it's very annoying
hello, when is an update for the live channel problem which puts an http 403 error which searches for a channel for 5 tries and which tells me to call my suppliers, when they have no problem on their server, and that's it done on my 5 servers that I have on the formulate z11 pro max, already factory reset at least 8 times and all the updates are installed
sam yet it is marked "help formulate z10 pro max/mytvonline 2" as the title
hi do i need to paid for the apk mytvonline, if i can install it on my formuler z11 pro max?. where can i get the paid version. thanks
hello, no mytvonline is free and is part of the box, if it is not present just go to the market to download it
It could be also some problem that happens under some unusual configs. Factory reset helps in that case.
hello, I have the same problem with my z11 pro max, I have 4 servers and it's the same with the 4 servers, I've done at least 4 factory resets, tested on ethernet cable and on wifi, this n it's not due to my connection because all my other devices work flawlessly on ethernet as on wifi, I have a z8 pro and on that everything works flawlessly
Hey,
My Formuler z11 won’t start up again after been off after electrician went off. The Formuler logo gets in with the 4 colour balls and won’t go any further.
Who can help me to solve this problem?
try to do a hard reset, it will go to factory configuration
I want to use it too, I paid $300 dollars for my Z11 Pro Max and it doesn't even have a working IPTV app! Unbelievable that I have to buy TiviMate still
I should've just bought an Orange Pi 5 if I'm gonna have to use 3rd party IPTV apps. And the Orange Pi 5 blows away the Z11 Pro Max for 1/2 the price.
Formuler is losing it, big time
well the problem is that the 11 pro max is young, it has these youthful bugs, I had the same problem with the 10 pro max and the 10 pro max after the updates now it's fine, you just have to wait and keep the bug forum current
STALKER error: A Network Error Has Occurred
For no reason at all, totally out of nowhere. Need to use StbEmu, TiviMate, and OTT Navigator instead of MOL3.
I can give staff my login details if you DM me, but only if you're actually going to fix something for once
Thanks, Z8 Pro was such a joy to use instead. Only problem was you can't change MAC and SN
personally I want to stay on mol 3, I don't like the other apps, I just hope there will be an update that will fix the problem
First do Mol3 data backup. Reinstall MOL3 or if not to much work, better factory reset the box.
I reset the box when it left the factory and it still does the same, if it did it on a single server I might think it's the server, but it does it on all my serversI reset the box when it left the factory and it still does the same, if it did it on a single server I might think it's the server, but it does it on all my servers, on the other hand on my formulate z10 pro max with the same server I have no problem
thank you, I'll look at that, the update was already done not long ago with the latest version
hello everyone, for two or three weeks my formulate z11 pro max while I watch TV marks me you are not connected to the network, yet my internet works nickel, I change cable and the same
The physical keyboard fix will be applied in the next release.
As a temporary workaround until the next software release, please set the Formuler remote option to off.
ok thank you, I'll wait for the update then, have a nice day and best wishes to all
Please set below and check again
Home screen > Settings > Device Preferences > Accessibility > Formuler remote > Set to off
on the other hand, by deactivating formulate remote the 3 buttons at the bottom of the remote control no longer work so it doesn't suit me either, formulate would have to fix this, because on the z10 pro max everything worked nickel
