2 or more iptv suppliers
  • When we have 2 or more iptv suppliers, In Favorite and History, it is not possible for now to differenciate 2 identical series from 2 different suppliers:
    there is no indication of the supplier. Please, could you put a mark stating from wich supplier the serie or vod is ?
    cedel
    hello, when you go to the submenu in the vod, when you go above it is marked at the bottom right on which server it is located... :winking_face::smiling_face:
  • NO!
    You should read correctly...this happens indeed in the categories in the "submenu" EXCEPT IN "FAVORITE" and in "HISTORY"
    A subcategory can only be from 1 provider at a time, but in Favorite and History, the VOD and series ze mixed from 2 providers, and there is no way to see which one comes from what provider.
  • NO!
    cedel
    strange, because I see my supplier displayed when I go to a subcategory, as I have 4 suppliers when I go to a category, it marks me at the bottom right the name of the supplier like that I see on which server am I on if I select the film or series
  • you don't see your supplier if you have placed 2x the same VOD/SERIE from 2 different suppliers in Favorites.
    Idem when you look in HISTORY
    cedel
    yes in the favorites we don't see it, but before putting it in the favorites, you will look for the film or the series in the chosen directory or at the bottom right it is marked the suppliers, so just look before put it in favorites
  • Correct me if I'm wrong but you cannot use more than one supplier at a time can you?...in "content sources" it seems only one subscriber can be active at a time, and I even saw that unless I first turned off my primary one, I couldn't turn on a new one. right?
