Posts by PJD1984
    Hi I Have noticed an issue when playing 4K files via Plex, if the file contains a DTS-MA audio track there is a very slight lip sync issue.
    The Nas is a Synology, I did wander if the server maybe underpowered, but the video plays flawlessly just a very slight lip sync issue, just enough to be annoying.
    Also the other thing I noticed when you rewind or fast forward it takes about three second for the audio to start after the video has.
    Has anyone else noticed this issue
    Hi On the Z10 pro Max Apple Tv is available as an app I can add my account but will not display any of my library but can manually search for a film and play it.
    But no Apple Tv on GTV
    After removing all Nas Drives from GTV if I go back into MOL2 Settings DVR Options In both Recording Storage Location and Timeshift Location the Nas Credentials are still saved and no way of removing from DVR Options, Also after reset still wont connect to NAS
    Perhaps, but the solution is to unCheck the [ ]Reconnect on startup box, reboot the box and then that Mounted Device will be deleted.
    Warning: You cannot EDIT any mount info so you must follow the procedure above and then RE-enter your network connection info.
    Cheers!
    I did uncheck the Reconnect On Startup and then attempt to unmount but I never Rebooted the device but as its working Im not going to to do that right now.
    Whats the Z10 Pro Max like was thinking about picking that up as well ?
    Why are you unable to delete it from the NAS menu?
    What happens when you press the delete button on the screen?
    Get error message on Unmount 'Fail to disconnect, Check Disconnection perimeters'
    On Delete 'Network Storage Unmount Fail'
    I'm going to reboot the Both Nas' as I was playing around with them as I discovered both were leaking DNS and IP when running VPN on QVPN, hence needing to run VPN at router level which has stopped the the IP and Dns leak
    Is the network address changed? Normally you give your NAS static ip, same also done on GTV?
    Everything is exactly the same the second nas connected fine but was not connected before I added VPN profile at Router level, The First Nas was connected and then I added VPN Profile, the NAS Static IPs are the same as they were before any Router changes. I got a feeling if I re-add it it will probably add fine, but cane delete the old profile
    Hello I Had my GTV setup to record to my Qnap NAS and everything was setup and correct, However the GTV can no longer find the Nas and I can neither Unmount or delete it, the only thing I have changed is that I Have setup the VPN directly on my router rather than the GTV which has helped massively with the speed and quality of the stream. Has anyone else come across this and a solution.
    I Have checked a second Nas which is connected to the same router with the same setup and I have managed to mount it and record to it.
    Hello my GTV will not connect to my new router, its a 802.11Ax Asus Rog router, works fine on another basic router, keeps saying the password is wrong, which its not I've tested it on other devices, and the GTV connected to my Iphone fine, Any help would be appreciated
