Hello I Had my GTV setup to record to my Qnap NAS and everything was setup and correct, However the GTV can no longer find the Nas and I can neither Unmount or delete it, the only thing I have changed is that I Have setup the VPN directly on my router rather than the GTV which has helped massively with the speed and quality of the stream. Has anyone else come across this and a solution.
I Have checked a second Nas which is connected to the same router with the same setup and I have managed to mount it and record to it.
