I am moving to another provider but i would like to keep my current FAV, is this possible?
Still having an issue (doesn’t seem as often) where I’ll open MOL2 on my Z10 Pro Max (XC API Connection) and groups of my channels are just missing. The groups are there but it’ll just say no channels in them. Today I opened it up and my locals were in there but every other group said no channels. Quick restart and re-opening of MOL2 and all was back to normal. I took a video but I’m not really sure what it would do to help much but can upload if needed. Thanks!
I have noticed the same issue with few of Z10s i have on this version. No channels showing, even if i refresh no channels until a reboot is done.
What method were you using to factory reset the device?
Explain what "fails and gives option to factory reset" means in more detail.
In any case, what you describe is abnormal.
Every often when it comes out from standby the box will have failed to load, it is automatically at the option to reset the defaults. Has an option to continue loading normally too but as soon as OS loads it fail back to same screen.
I followed what Sam suggested and will keep an eye to see if it happens again.
Keep having issues with this one box have done factory reset many times before as it fails and gives option to factory reset.
However this time it’s stuck on formuler logo, is this faulty, any way to recover it?
To keep epg and channels updated I like to refresh my connection daily. Is there an option which I do this at certain times during the night?
Is there an option to force a epg to load. I am having strange issue where with MOL2 epg only shows once i go to the channel or at times hoover over it. Using tivimate it loads straight away but MOL2 is not loading automatically unless i go to channel.
i have cleared epg cache etc but still same issues
If you delete that file and want to reinstall it, can that be done, and if so, how?
should be able to if factory default or reinstall from google store
is your box connected via wifi or cable to your router?
cable
I found the issue why I could not connect to the Via Android TV app with my iphone. Go to settings > apps > see all apps > Android TV. I uninstalled the Android TV remote Service and then it worked!
Thanks this worked for me too
I am under the impression that the picture-quality is not as good /sharp with the new official 10.10.25 software.
Somewhat hazy, and some pixelation visible.
Do other users expirience the same issue ?
4k25Hz judder issue seems to be resolved.
i dont see anything different
Any update on this? Is there any other options to backup channel fav list and restore via ssh or something?
Is there a fix to stop it going to main menu from standby?
Same issue here running latest beta, I thought it was provider until I tried different app.
It’s on random channels, very bad stuttering every second.
Thanks bobbyboucher am still not sure whether to change from the 4k Fstick to the F8 Pro as am worried that I will not notice any real difference in quality
I'm really back to square one
if i was you, i would stick with fire tv. I upgraded and still in regret. But love the MOL2 app and the remote for sure.
yep this was sitting right on top of it so moved it away.
strange when i lift it its ok when i put it down it did that, removed my satellite box and issue gone, add back and issue comes back.
Seems some sort of interference
My Z10 is stuck on fast flashing white light, cant really do much.
Managed to factory default but still same now cant go past choosing even language.
Did a factory default and it seem to have resolved the issue. I did try clearing cache, data etc but no change until factory reset.
I am checking with provider first and see what he comments, will delete some apps and reinstall to confirm issue is not just on mol2.
Will update once I have more confirmed info
Change between Normal and UTC EPG under connections -> sub. Check also time, gmt and location.
Same issue, seems like it’s loaded on few channels and that’s it before I could see it used try to load but nothing as such happening anymore.
I had issues with picons not displaying and waiting for a fix on it with next update but now my epg has stopped loading, works with other apps just not on Z10.
I understand issue might be provider but what is no different on Z10s that it works on all other apps I try except on this device.
Any suggestions?
Yes same issue here just tried
The recording were done using Enigma2 boxes so i assumed it would be different.
Just tried it and no does not work. I have below files per recording.
.ts
.eit
.cuts
.meta
.sc
I have moved from a Enigma2 box to Formuler and have previous recording ending with .ts files, is it possible to some how update index file so i can view this under mol2 recordings?
Strange been having similar issues on 7 installs I did, I keep getting long delays loading channels and also in some cases same error as in earlier post.
Changed to cloud flare and been ok till now. Don’t make sense to me.
Edit: maybe not keep having issue with slow loading and error still, so have been running mol2 and other app side by side but issue only on mol2 app.
Please pm me, need something to check with you later.
Just sent a PM.
Disconnect Mol2. Btw. what are you using exactly for connect with your provider, registered MAC /ID Stalker portal, XC Api with login portal or m3u playlist?
Go to home menu -> Settings -> Apps -> Mol2 -> clear cache and restart the box.
Thanks for the reply. I am using XC API with login portal, just adding the URL address with the username/password.
I have also factory default it few times in addition to what you suggested. Been at it since yesterday to figure out to how to get it working.
Can anyone from Formuler support team comment on the issue please.
did you get this resolved, i am having the same issue on Z10. As a test i installed tivimate on the box and it loaded within 10 seconds.
Hello
New user to formuler tv, have an issue where picons are not displaying on the mytv.
As a test I also installed tivimate app on the box and no issue, loaded within 10 seconds. I have moved from firestick and hoping to have this working.
I spoke to provider and there is no issues at his end which obviously is confirmed by third party app install.
Is there anything special setup required on this box either from my end or providers?
