I installed the new update, it says firmware 10.10.48, not 47.
Posts by Sun79
With this beta version, there seems to be a more sandy image on the screen.
Thanks, 175n 🙏.
Formuler kutusundaki uzaktan kumandayı neden sevmiyorsunuz? Bu arada, uzun zaman önce yaptığım programlanabilir
I love the formic remote, and I want to use that remote to pair it. I don't like the LG TV remote. I want to control the TV with the Z10 pro max remote.
Greetings, I could not match the remotes of my Z10 pro max box with the TV (LG Nanocell) TV, the Z10 remote can turn the TV on and off, but the features such as volume on and off and source do not match, what should I do!
MOL3'ü mevcut cihazlardan uzak tutmak biraz ileri görüşlü (veya açgözlü) görünüyor. Her eski modelde mevcut olmasını beklemezdim ama mevcut amiral gemisi modellerine gelmesini beklerdim. Z10 Pro ve Z10 Pro Max müşterilerinin özellikle rahatsız olacağını hayal ediyorum.
Açıkçası, bir donanım kısıtlaması varsa bu bir şey ama içimdeki şüpheci bunun tamamen muhasebeci odaklı bir karar olduğunu düşünüyor.
You're absolutely right 👍, it shouldn't be for the money, it hasn't even been a year since I bought the z10 pro Max, we want mytvonline3 too.🙏
Why dream, there is no difference between the Z10 pro max and the Z11 in terms of software and hardware in terms of mytvonline3.
why and why did mytvonline3 only come on Z11 series boxes? As we Z10 pro max users, why didn't mytvonline3 come to our boxes? just for the 10 Euro difference !!!
When will the mytvonline3 application be published, can you give information about this subject? :katlanmış_eller:
I have 200 mbyt fiber internet speed to my Z 10 pro max box, should I get it via wifi or connect with ethernet cable.
hello, with the last update, there is a sound problem in my z10 pro max box, and the volume control is not possible with the remote, the sound is zero, what solution would you suggest?
hello, this box iptv feed 4.2.2 codec broadcasts do not open the channel, I try with vlc, but the image is stuck, it is not fluent at all and mytvonline 2 does not open it, opens it with tivimate vlc. Is there still no work on this issue in the Formuler development team?
The new update has arrived.10.10.30🤔👍.
For Z10 formulary devices with the 27th update 🤔.
Bir kumar oynadım ve bir netflix.apk indirdim ve onu z10 pro max'a yükledim ve tüm standart menülerle mükemmel bir şekilde çalışıyor.
hello, what was the image resolution of Netflix in Z10 pro Max with the downloaded apk?
Definitely do not install this new application, Facebook ads appear on the screen. I went back to factory settings.
yuv422p10le interlaced 10 bit 422 interlaced yeni çıkacak yazılım update ile bu codec yayınlarını izleyebilmek istiyorum.mytv2,vlc,mxplayer,none bu codec yayınını z10 pro Max üzerinde açamadım.lütfen bunları dikkate alın Apple 4k tv bu yayınları açar Z10 pro Max neden olmasın!Çalışmalarınızda başarılar dilerim, teşekkürler.
The iptvextreme application on my phone opens this 4.2.2 encode 10 bit broadcast. Z10 pro Max does not open 😒, dear Formuler developers please take care of this 🙏
yuv422p10le interlaced 10 bit 422 interlaced,I want to be able to watch these codec broadcasts with the new upcoming software update.mytv2,vlc,mxplayer,none I could not open this codec broadcast on z10 pro Max.please consider these, Apple 4k tv opens these broadcasts, why not Z10 pro Max!I wish you success in your work, thank you.
I had fps (flickering, frame skipping) problem on Z10 pro Max boxes, this problem was solved with beta update. but the original software update still hasn't arrived. Z 10 pro Max with a powerful processor, with new updates, Formuler team can offer us a much, much better Z10 pro Max.
Greetings Sam and the formic team, we are looking forward to when the new update, which is free of problems, will come. Good work to the whole team.
hello SAM, these codec programs open close to 4.2.2. - main concept codec - skyview - cyberlink - coredvb - theater - dreamdvb. thanks 🙏.
4.2.2 broadcasts with this codec opens Apple 4K box, I think Z10 pro Max is a better and more powerful box than Apple, don't you think!
Hello SAM, I can't watch 4.2.2 codec broadcasts with my forular Z10 pro Max box, is there a work around for this? Please I want to watch these 4.2.2 codec videos and broadcasts with this box 🙏.
hello, good evening, when will the new software come, can you let me know? We are looking forward to it.🙏
yes, my z10 pro max has the same problem now, when stand by mode is turned on again, the screen returns to the main page, it is fixed when the formula is restarted.
Hello, yes the image quality is a bit low, full colors they are not lively, the contrast and sharpness could be a little better. thank you.
Thanks to SAM and the formuler team, the flickering problem in live broadcast channels (sports, documentaries, movies and news) has been solved 👍 when you change the channel, sometimes the screen goes black (1-2 seconds), there is no problem in vod 4K movies. There is some flickering in Amazon prime As for the normal software, maybe our devices will be better, thank you 🙏.
A few more tests: (real) 50 FPS and 60 FPS channels are running very smooth, channels that get displayed as 25 FPS (if you hit the info button 2 times and look to the bottom left corner, in the normal info it still says 50 FPS) still have the judder problem. Can you pass this to the developers, so they can fix it for 25 FPS channels too? Would be great!
hello, when will these problems be solved? We couldn't watch a fun match or movie on Z10 max pro devices.
because the processor of the television does not always work properly, the ram and memory are low, and I use box for similar reasons.
hello friends, the iptv broadcasts I watch on the tv player are very good, there is no flicker and pause, but when I watch it with the Z10 pro Max, there is a constant flicker on the screen, especially in the live broadcast matches, but the duplex play, the player of the same broadcast television, is also without problems. It will be fine?
Hi Sam, should the z10 pro max box afr setting be turned off or on while watching the match on live broadcast.
There is a true motion setting, I turned it off, but the same problem persisted. Thanks for the answer, Sam.
While the ball is in the air, it bounces off, there is clouding in fast movements.
