I have a problem/issue with my provider after this BETA update, meaning everything works, it loads channels, EPG , VOD, etc, then some channels open right away, but others do not open, instead i get a black screen and network error, this happens in both MAC and XC. You may ask why i know it's a formuler error/bug? Because in the same channel if i go right to EPG and choose to start the live stream it opens the stream, then i scroll to the end and i get almost live stream, i stay for a bit and then when i exit epg and return to channel it opens the channel, problem is if i change to another channel the network error returns.
I did everything already, reset box and mol3, changed vpn settings from wireguard to openvpn, dns on formuler from auto to off, and things get better? maybe placebo and after awhile network error again.
Refreshing portal helps only in the channel we are at the time of refreshing, after changing to another channel the network error returns...
I'm not sure if it helps, but on other iptv apps we can choose the stream quality and change it from "auto" to "best available". i've noticed that when it's on auto on several iptv apps i have issues and when it's on "best available" less issues...
On MOL3 we should be able to choose stream quality on a specific channels or on all channels (almost all providers have it). My provider has 3 streams of the same channel (SD/HD/FHD/sometimes4k). Yet the "SD" channel could probably be streaming in FHD and the FHD streaming in SD and sometimes while in the same channel i see the resolution changing from FHD to HD or SD. Not sure if i'm making any sense...
Too many things can be happening, but i'm almost sure something is wrong when i open channel, probably formuler decoder doesn't know which stream to open and on EPG as it opens with different decoder (i've noticed media player is different on EPG) it gets the only resolution available on EPG and then when returning to the main channel probably the live decoder used the same quality that was on EPG. But again, i'm just speculating from my own experience...
PS: This behavior is new, meaning i got network errors in the past with previous FW, but i could never open EPG on that channel either...
