I am 100% sure the app is blocking my portal. It works on tivimate.
How can I raise a support ticket?
If you go to content sources/data sync/epg data & select clear and update EPG will that get the guide back? I have had this work for me. Unsure if you have tried it or not. Try this to see if it will load the EPG.
Hi thanks for the reply. I have a issue that mol3 is blocking my portal address.
Thank you for your support.
I have tried with vpn and without as you suggested.
The portal I can add on my other app with no issues. Just seems to be on mol3 which was running fine until the last few days.
Need some help please. I was using my server all fine up until this week. I had the 'no information" on my epg.
I removed my account and now it doesn't want to connect. It works fine on another app. I have checked with provider and they have not blocked it. The message I get when tring to add is..
Connect failed
Check portal url
Sever returned http 403
Code 1005-400
The weird thing is I am able to add my other server with no issues.
Have you tried powering down the box and then unplugging at the mains and leave it off for 10 mins and then connect back up?
Yes I have tried that.
Wonder if I need to do a factory reset maybe?
Eveytime I either manually or when I set schedul to refresh contents...I allways get a error for 10 minutes I am unable to view any stream or vod content. This is so annoying, does any one know why this happens?
Also my z11 pro has become really slow and takes ages to respond to basic instructions?
Any help will be really appreciated
Hi
Under vod section when trying to watch a trailer of a film, it doesn't seem to open.
I press play and it looks to open utube then drops back to the film details.
I have tried using another program and trailer works fine so I'm sure it's the mytv app issue.
Thanks in advance
Since the update to the new firmware I'm having issue with subtitles.
I can search them but when i try downloading it states failed.
I have registered on open subtitles and logged into my account but still same issue.
Any help will be appreciated
Oh hahahah, and no kids they watching netflix or downloading stuff?
No other usage for my Internet, could also be internet provider but doing a speedtest not issue with down or upload
Hi,the fact that you not have the issue (freezing&glitching) on fhd channels only,but also on vod makes me suspect there is a provider issue involved,or do your vod work flawless on different app,than mol3?
Yeah all works fine on the other app including vod.
Will speak to the provider at see if anything on his side. Thanks
In theory 50mb should be fine for tv.
is your box connected directly with a cable from the modem?
No switches behind it?
Oh and dont speak about iptv with your internetprovider, they dont like ik because its illeg*l.
Provider as in the iptv provider not my isp. Lol
Yeah straight connection router to z11 with cable. Even tried wifi and still same issue.
I'm sure only 20mb should suffice but can't get my head around it.
How is your internet speed,as it is limited in the z11pro vs the z11pro max?
Hi
I have fibre broadband and its 100mb download and 20 upload.
I haven't spoken to my provider due to it working fine in smarters app on fhd
Do you have HEVC and HD channels with the same issues?
fhd is the issue
HD and sd work fine
Don't have Amy hevc channels
over the past few weeks my fhd channels are constantly freezing and glitching.
When using another app they are completely fine. Can anything be done to rectify this?
I'm using a ethernet connection and also have tired WiFi but same issue.
This happens with vpn and with it turned off also.
install external player like vlc and set as player for series and vod, test again.
Ok will give that a try
hi, when using the default player and watching TV series, I'm getting loads of buffering. The progress bar only downloads a few seconds ahead but on occasions slows down which the stops the playback.
I have tried other devices and iptv smarters and no issue with the same episode. Can anyone help?
hi
search for '404' in the PM 11 section, and you'll find some results (same here, not always, but mostly - here mostly back after about 5 mins - still very annoying I must say ...)
Will do. Thanks
Why do you do refresh on channels and contents every day.
I never do it and have no problems with errors?
Hi, the reason is football live links change sometime by my provider.
hi,
When I do a refresh on channels and content each day manually, when it completes I go to refresh contents and I get an error message.
I've spoke to my provider and he insists issue is not on his side.
The error message...unable to open stream server error http 404.
I then have to wait 20 minutes before it comes back on again, any one had any similar issues?
hi, I have the similar issue.
When updating content for new streams for live content, once the update has been done the box locks off all my channels. I have to wait atleast 10 minutes before the streams start working again. Very frustrating
hi,
Moved from 7+ to the new 11 pro max.
Couple of issues.
Vod doesn't seem to save the progress that has been watched, it starts from the beginning. Checked all the options and is set to ask everything. Using vlan as player.
Next is bbc iplayer is not on the Google store and the netflix thats on the market store is old and doesn't let me update it.
How comes these 2 basic apps are not on the Google store?
Other than that loving the box and keep up the great work!!!
