I'm on vacation for 4 weeks, I can experience it.
Posts by Balkanboy
Don't understand why I'm busy, but patience is a good thing.
Yes, I understand that, but for the Z12 there is also a beta version MyTV3 available, right?
But why update mytv 3 and there will be a mytv 4, what is its purpose? Will MyTV 4 come automatically if it's all right as an update and refresh, and why will a revamped beta version of MyTV 3 be released? I find it confusing and can't read it anywhere, when the MyTV 4 comes out I would like to use that of course, who can explain to me why there are 2 different beta versions of 2 different apps?, sorry I don't understand.
Well only I don't understand. There will be a new update for the 3 and a whole new mytv4 , you can choose whether so , or the 4 will come very late and that therefore mytv 3 will get a faster update I have version
The content cannot be displayed because it is no longer available. -
Is it necessary to install the beta, have no problem now, and is there already a view when it will be officially released?
Okay now it's clear thank you for your reply.
I don't understand it right now, we can now choose between the three or the four of mytvonline And what are the differences then
Hello, is there already a prospect when it will officially come out or is there still many problems that need to be solved?
I'll wait for 4 to come out, I don't know when the official version will be released.
If you are going to install that, everything will remain your favorites or you will have to do everything again.
do you have to re-enter everything like the channels
Thank you everyone
What time should you set the EPG Interval Update time to renew? 24 hours?, but now I have set it to every 12 hours is that good or not?, I would like advice, otherwise very satisfied with this Z12.
I bought this from an expert.
Scanpart Ultra High Speed HDMI kabel met Ethernet 2.0m 8K60Hz 48Gbps Kopen? Snel in HuisDe Scanpart Ultra High Speed HDMI kabel met Ethernet 2.0m 8K60Hz 48Gbps koop je op expert.nl of bij jouw lokale Expert. ✓Beste service ✓140 winkels ✓Snel…www.expert.nl -
... I bought an ultra high speed hdmi today a good quality cable, the other one also worked from the box itself but I always want to have it perfect 🙈, I have absolutely no problems with it and it works to great satisfaction 👌👌
Please use one thread for one issue and not two of them with same postings! Decide which one this or other.
In other thread you told HDMI Port switch works now, did you also installed latest Firmware v. 12.10.06?
yes i hef
Display More
The hdmi cable supports QMS.
so if your tv supports it, and you change channel from a Dutch channel (50fps) to an USA channel which is 23fps, you shouldn't see a 2 seconds black screen if AFR is enabled.
If you have AFR enabled and your tv doesn't support QMS you see 2 seconds black screen or so.
If your tv supports QMS (Quick Media Switching)
And you use original cable, you won't see anymore the 2 seconds black screen if you change a tv channel from 50fps to 23fps, or from 23fps to 50fps.
I'm using the included HDMI cable; that should be fine too, I think.
Things are going well right now since I used another HDMI port of the television.
I also read something about HDCP., it says 2.2 I can change to 1.4, what is the difference here in sorry for all my posts
I have now done it in another HDMI port, at the moment it works well (hopefully it will be solved) and otherwise I will come back for a solution, or I would like to hear if more people have a problem with this.
Now I have a problem, when I turn the box on, there is no signal to the television that has to take the power off and wait a few seconds... Turn the power back on and then the HDMI picks up signal again and I get a picture..., when I turn it off again and turn it on again, it doesn't get a signal again, is that the box is a known problem or is there a mistake in the box.
Well I bought first impression is good., is a nice extensive device., is currently everything installed and works flawlessly, see no problems yet.
A. Okay.I think I'm going to buy one today. is not difficult for me to plug an play or are there things I need to think about in terms of settings.
What is the difference with HDMI then? Why could that cause a problem? -
hellookay I will wait with that
Hello, is the Z12 already stable like the Z11? I am considering buying it, but if there are still many bugs, I would rather wait. -
oke thanks i hef al z11 pro
Hello, is there much difference between the Z11 Promax and the Z12? I'm still in two minds about whether to get the Z12.
Is there going to be another update, or is it finished now?
Difficult to answer unless you have a crystal ball,if it goes like the z11 it may take up to 1-1.5 years of updates to get everything right and stable.
However,considering the quick FW update and the already announced future updates,i believe max energy of devs, is put in new ultra and things may advance much quicker
thanks
Hello, is the switch from a Z11 Promax to a Z12 Ultra wise at the moment or are there still many problems that need to be solved?
Okay, thanks for your answer, I had a hard time because it took a lot of effort to install, thanks Henkie, oddbob
yes I know, I have no idea
You make a backup of mytv, it would almost sound logical that it would be possible, have you tried the z12 as well?
If I make a backup of the Z11, can I upload it to the Z12 so that all my favorite channels are there or do you really have to install everything because Mytv 3 is the same anyway?
Bump
I think they are busy with the Z12 instead of the Z11
Explain in more detail how that works, and does it also work in Bulgaria, for example?
