Now I have a problem, when I turn the box on, there is no signal to the television that has to take the power off and wait a few seconds... Turn the power back on and then the HDMI picks up signal again and I get a picture..., when I turn it off again and turn it on again, it doesn't get a signal again, is that the box is a known problem or is there a mistake in the box.
HDMI problem is known to this problem.
- MYTVOnline3
- Z12 Ultra
Balkanboy -
March 15, 2026 at 6:45 AM
I have now done it in another HDMI port, at the moment it works well (hopefully it will be solved) and otherwise I will come back for a solution, or I would like to hear if more people have a problem with this.
I also read something about HDCP., it says 2.2 I can change to 1.4, what is the difference here in sorry for all my posts
Use HDCP 2.2 as it is backward compatible with HDCP 1.4
Read more about HDCP here: https://www.avaccess.com/blogs/guides/w…dcp-1-4-vs-2-2/
Things are going well right now since I used another HDMI port of the television.
It should be the ARC HDMI port
Have a nice Sunday
