Does the z11 pro model support Sonos surround sound set up? I have a Sonos Arc soundbar with sub so would like to know if the z11 is fully compatible with such devices? Thanks
Still have the volume issue where the volume bar doesnt always appear on screen whej adjusting. Its becoming very annoying. TV is an LG and is connected to a Sonos Soundbar. It is an intermittent issue sometimes it works as expected then other times it doesn’t. Can this be investigated please?
Been having a nightmare with the volume control, intermittently it works but then decides to not do anything when I’m trying to up or down the volume. Very frustrating to the point I’m close to returning the z11 pro device.
It’s very intermittent, sometimes the volume bar shows on screen but then other times it doesn’t. When up / down volume nothing happens. Need to keep restarting the z11 device for it to resolve itself. I’m more than sure this issue has occurred since the last major update.
Do we know roughly when can expect this issue to be fixed?
Hello I’m experiencing same issue since applying most recent update on z11 pro max.
volume control function is being lost between LG tv and Sonos soundbar. Very intermittent issue seems to work sometimes then other times not.
The GTV-BT1 remote is set IR control is set to LG and Volume control is also set to LG.
When press up and down volume on remote it works intermittently also at times do not get full volume extend from Sonos soundbar.
Any help would be much appreciated.
Hello, I’m new and have just got a z11 pro max. I would like to have record functionality so keen to know which is the best storage device to connect with for smooth recording experience? Thanks
Yeah so when I used the actual LG remote it worked in that way however since pairing the Formuler remote with the LG it’s no longer working in the same way. Yes it can increase / decrease the tv volume but it’s got no control of the Sonos. If I want to increase volume further I have to do it from the Sonos app or revert to the LG remote which is a bit annoying. I would like to have full control with the Formuler remote.
Just so strange that they have all other brands but Sonos is missing
Yeah unfortunately it doesn’t list Sonos even when search manually. All other brands are there!
Would like my GTV-BT1 remote volume control to manage the volume on Sonos Soundbar however when go into Setup Volume Control for remote it does not list Sonos as a brand.
For now when I use volume control on remote it just manages volume on LG TV
