Would like my GTV-BT1 remote volume control to manage the volume on Sonos Soundbar however when go into Setup Volume Control for remote it does not list Sonos as a brand.
For now when I use volume control on remote it just manages volume on LG TV
Unable to pair remote with Sonos Soundbar
For now when I use volume control on remote it just manages volume on LG TVNo, not all.
Did you use the search function?😃
Yeah unfortunately it doesn’t list Sonos even when search manually. All other brands are there!
Will have a look tomorrow.
Checking the app if i can do something with volume control. Not with formuler, tv and projector. But soundbar.
Just so strange that they have all other brands but Sonos is missing
Yes, sonos is known brand in europe.
If you connected your soundbar on a HDMI ARC port on your tv. I thought you should connect the remote with your tv brand and then volume should work with soundbar also.
A friend of my has also soundbar. Connected with hdmi arc. And many its setting on your tv then when use volume tv, the soundbar takes it over.
Then you can use the remote with your tv brand.
Yeah so when I used the actual LG remote it worked in that way however since pairing the Formuler remote with the LG it’s no longer working in the same way. Yes it can increase / decrease the tv volume but it’s got no control of the Sonos. If I want to increase volume further I have to do it from the Sonos app or revert to the LG remote which is a bit annoying. I would like to have full control with the Formuler remote.
With your actual remote it works.
That one is programmed on your lg tv.
When you push volume up on tv remote, your sonos go harder.
Then you program the formuler remote with lg brand for tv.
Should work the same then.
Been having a nightmare with the volume control, intermittently it works but then decides to not do anything when I’m trying to up or down the volume. Very frustrating to the point I’m close to returning the z11 pro device.
