I think I watched the error in real time while now using the NAS drive instead of the USB-stick. I had a scheduled recording. I closed the MOL3 app (last line in the settings menu) and put the Z11 box in sleep with the power botton of the remote. Because I can see the files from the computer, I realise that the "_info.json" file and the ".m3u8" file was correctly created at the starting time of the recording, but no ".ts" file had been created! When I manually started the MOL3 app from the remote control and I can see that the ".ts" file was created (creation date 6 minutes too late). Another channel (the one last used) was shown. I put the box to sleep again. Checking the files again some minutes later I realise that the recording had ended too early, only 2min 17 seconds / 43MB was recorded.
Many recordings ends just after a few minutes even if the Notifications say it ends the correct time even.
Also behaviour seems to depend on if you are recording the same channel that you watched / last watched or if you are recording another.
I’m so confused. Sometime no recording at all and no notifications. Sometimes just records a few minutes with Notifications as normal.
If the recording will succeed seems to depend on different factors, if you watching the same time or not. If you record the same channel that you are watching or have been watching or not. If recording starts from sleep or not. If recording starts from closed app or not. If you operate (starts app if not running, close app while while running, change channel, use menus) while recording or not.
I have done more test now. If I watched the same channel as the next on schedule for being recorded, its may working?, at least the last two was recording successfully this way. Then I schedule another four on different channels (put the box into sleep with the power button while the app was running). Out of these four only two recorded correctly - first one ok, second one was was only 1:51 recording instead of 40 min (Notificaions tell the same 1:51), third ok, fourth missing (no notification), When I later turned on the TV to check it was dark, pressing power button to wake the box from sleep show the desktop - the app had been closed.
So it looks that using NAS for recording instead of USB-stick also have the similar kind of problems with missing recordings.
I will give up using this box for recording now & hope you can solve this issues as soon as possible!
I send log file to you some 50 min later then the last recording should have ended, #1995104
