This may seem like a weird question, but when you are running 2 Formuler boxes and one is blue tooth (BT) and the other is infrared (IR) only.
The Z11 Pro Max responds to both the IR remote and the BT remote as does the other box, a GTV. One remote has BT the other is IR only. I need to block the IR "eye" in the Z11 Pro Max so it doesn't respond to the IR signals from the non-BT remote.
So, where is the IR "eye" on the Z11? Probably in the front facia of the box but I can't see it. I want to put some tape or similar stuff over the eye.
Cheers!
