YouTube works perfectly for me what is the advantage of either of these? Am I missing something here
Posts by jmhall
I am going to experiment as It may be an EA3C audio codec problem, it's VOD 3840x1920 resolution and plays no problem on my iPhone
Not an audio codec problem just a problem with the device not able to play this resolution
My provider has VOD content that is 3840 x 1920 and my formuler z11 pro max won't play any of them I have even tried external players like VLC, MX player with no luck. Anyone have any suggestions on how I can play these
App won't start at all on android I have tried to uninstall and tried to scan QR code on portal on z11 pro but 5hat won't scan either
thanks for the info
can anyone please tell me where i can purchase the gtv-bt3 remote by itself? i have struck out trying to find out where
Cloudflare blocks IPTV, you should be able to find a few posts about that here on this forum, thanks for commenting though.
I have been running two years in Canada using cloudflare with zero issues , just for the record
Cloudfare
1.1.1.1
1.0.0.1
has the aifr been removed as its no0t an option in my menu
Z11pro max for over a year I use stalker portal and have had zero issues with the exception of Amazon Prime video app not working
. Mytv3 works great all the time
The app doesn’t allow external displays to be used so it won’t work
So you. Have personally tried this and it did not work via usb-c to HDMI from android tablet is that what your saying?
Can I mirror android tablet to tv screen with HDMI cable and watch mytvonline+ app
Any technical reason why not? Just to help me understand the limitations.
Is it not possible to screen mirror mol3 app to tv ?
THANKS FOR GETTING THIS ONTO IOS GUYS...
The QR code option isn't there like the android version
Is there no way to export your settings like there is for Android so that all the portal settings just transferred to your iOS
Thanks guys for your ongoing efforts
i may need to factory reset my z11 pro max as amazon prime and apple tv wont play videos and am wondering if all of my VOD favorites and live tv favorites will be restored after doing this
backup was done today on installed sd card
Where do I download it please and thank you for all your efforts on this
No luck on this one either thanks but I guess it's a no go for me and As amazon was zero help either
Where can I find it
Well even after today's new firmware update it still does not work, although the update is nice so far
Yes thanks
well after trying a number of differernt apk files still no luck so i suppose i wait for an update
thanks for all your help it is appreciated for sure, but i still get the "something went wrong" message when trying to play any movies yet live tv seems to work. This app was working fine until about 4 days ago then just stopped working, i thopught it may be my account but it works on my smart tv, my tablet, my phone etc no problem.
No luck file was no good
Please note, no uploads or link share on forum of any unknown files!
This can be done private through email if other user accept. Thank you.
Sam are you able to provide any wisdom for me ?
anyone else using the amazon prime app on the z11 pro max having issues? it starts fine but will not play videos it simply says cannot play right now with a link to their help page. the app works fine on all my other devices. i have uninstalled it rebooted and reinstalled with the same results, any suggestions
thanks
For Z8:
For Z11:
1. Like Pauljp already described!
or
2. Favorite -> chose VOD Title and hold OK (long press) to remove.
Thanks long hold worked for me
same on my z11 pro max some allow it and some dont
Thanks for the info I will stop trying to figure it out now lol ...it's been driving me nuts. Other than that the box works great.
I can't seem to get my z11 pro max to display at 4k 120hz. The tv is high end Samsung real
120 Hz and I'm using quality HDMI 2.1 Cable directly connected to tv. The highest option available in display settings on the box is 4k 60hz. Any suggestions?
