Posts by patchb01
Hi!
I wonder if there is a way to unrar files on my Z Mini that i have downloaded with File Manager + from my FTP?
Install the ZArchiver APK.
You also got latest version?
Thanks for your reply. I have the latest version of Stremio 1.10.4
The problem is fixed; I switched from ExoPlayer to VLC.🤗
stremio.
No audio with this type of video on the Formuler Z11 Pro Max connected to a Samsung soundbar.
Add the "Sport" and "Cinema" modes to the advanced display settings.
They show on my Ipad but not on my TV
Enable the metadata API.
Hi, could you explain how you connect your box to your PC to use MyTV and manage channels/portals? I'm interested. Thanks !
It was absolutely not my intention to make the situation personal or to be disrespectful.
I am simply a user of the device and I am satisfied with its performance, which is why I am proud to have acquired it.
My only goal is to have a good user experience and to understand any possible changes in order to make better use of it.
Thank you for your feedback. 🙏 -
Let’s be honest SAM : you never mentioned that MyTV would be blocked by developer mode. You only talked about bug fixes. This is nonsense. Show a bit of respect for your customers.
It did to me. Installed it and as soon as i started mytv it asked me to disable developer mode, if i don't it won't start. That's so bad i don't have words for that...
Reverted for non beta and i hope this don't become official or i'll try to never update and if it forces the update i will sell this POS!!!!
I really hope this is a bug because i don't believe no one uses developer mode to enable adb debugging and configure the app or watch it on computer when i'm not in the mood to go to the place where the formuler is as i do in every other box no matter the brand. No one disables developer mode. FFS formuler!!!!!!!!!!!!!!
It’s nonsense to block MyTV from starting with developer mode enabled. It is a violation of users’ privacy. I’ve never seen that on an Android box. Formuler has taken inspiration from Google’s policy.”
Update:
Second Beta Software Update 12.1.41 for Formuler Z 11 Series released.
Please read first post.
i installed it to take part in the testing, even though the second-to-last beta version didn’t give me any issues. 👍👍👍
Besides changing DNS and having a good Internet connection, it can be useful to have two different IPTV services as a backup solution. During major sporting events, high traffic can overload some servers; connecting a little before the event starts can sometimes improve the experience depending on the service used
A little patience, everything will be fixed and will run like a Swiss watch. The development team is doing everything possible to resolve these issues.
Try this solution :
PostRE: MyTV online 3 crashing VOD
Thanks..... work round worked for me and I have just switched metadata API back on and all seems goodMegandlolMay 21, 2026 at 5:49 PM Post : SAM
Yes, true. But that one isn't implemented as option (yet) in mol3 and mol4 my friend.
Why not implement it as an external player? that case, we could choose the app we're interested in.
TizenTube Cobalt gives you the impression that you are using the official Android app.
If you don't mind, I can suggest not exactly a solution, but a small workaround that may help narrow down the issue.
Try re-adding your subscription, but keep only the TV channels you actually watch. Also disable VOD and Series completely. Then test it for a while and see whether the crashes stop or become less frequent.
Another possible lead could be memory usage. Either the number of installed/running applications or an app that is not fully compatible with the Formuler may be contributing to the issue.
On Formuler, try long-pressing the Home button and use the red button to clear memory. Even after a reboot, the box may keep some apps cached in memory to speed up launching and give the impression of faster performance.
For testing purposes, at the beginning of your session, clear the memory, use only MYTVOnline, and observe whether the problem still occurs.
You could also install AIDA64 just to check RAM/storage status and overall system information. It may not give a definitive answer, but it could provide useful clues.
It is preferable to configure a DHCP reservation for the Formuler at the router level. The device has a clearly identifiable MAC address. It is also recommended to configure DNS directly on the router and leave the Formuler set to automatic mode.
I don’t know why you insist on using MyTVOnline when TiviMate manages your subscription much better.
For $30, get a lifetime TiviMate Premium subscription; in my opinion, it has all the features, and even more. You can even add EPG URLs.
Keep your Formuler to benefit from its performance, add TiviMate, and enjoy peace of mind.
In my opinion, I think you are using the same subscription on multiple devices, or the same IPTV provider on several devices with the same IP address. Your provider may be blocking the use of two simultaneous connections, or it may see it as abuse coming from the same IP address.
I think you could extract the M3U links, create a small local server, and then use the streams on each device, as long as only one connection is active at a time.
If it still doesn’t work, then either change your subscription — making sure to test it first with MyTVOnline — or use TiviMate Pro. User feedback says it is as good as MyTVOnline, or even better.
Let’s start again from the beginning.
Clear the cache and history of MyTVOnline.
Restart your network interface to get a different IP address.
Restart the Formuler device.
Launch only MyTVOnline and set up just one subscription.
The admins say that MyTVOnline works better with M3U and Xtream formats than with MAC/Stalker portals.
If you are using a MAC/Stalker portal, try using an official subscription. And if you have multiple subscriptions, always disable the others and keep only one active.
If none of this works, ask your IPTV provider to convert your subscription to M3U or Xtream format. Normally, it should work right away. -
MyTv Online 3 will not accept 1 server, have 5 other servers running okay.
This 1 server works on TiviMate, and IPTV Smarters no problem.
Any ideas ?
Thanks,
Mark7
The difference between IPTV players mainly comes down to:
the User-Agent
cookies
Stalker-specific headers
the handshake/token sequence
It’s also worth checking whether you are using the same server with the same IP address.
Please add the audio function via CEC.
👉 Check the recording permission; otherwise, wait for an official fix.
And what good is that supposed to do?
Because it gives us instant crash data, which allows us to fix problems more quickly instead of waiting for manual reports.
Also, the new MyTVOnline on the Z11 didn’t bring anything new. So it would be better to release a fix without too much advertising.
If you read the posts from last years, you will find many user requests where community users want to be beta tester. Before, it was closed testing! To be honest i would in some cases like the old way again but this is something that many users do not want/like.
There is official channel for those who do not want to Beta-test and wait for official and Beta channel for those who want to do it and report. Requests and Reports are coming from very much different channels, forum is only one of them.
So much for that topic. The fact is, no matter how you do it, there will always be dissatisfaction.
That is the goal.
Please now return to the actual topic, the Beta Update. Thanks.
No difference except for the addition of SmartTube. Same interface, same behavior.
On my side, every time I close my Z11, I will automatically send a bug report, without going through email.
MYTVOnline 3 settings > Player Options > Trailer Player > Smart Tube
it seems to me that TizenTube is much better than SmartTube. So why not implement it as well with MyTVOnline beta 12 ?
I,m not happy with formuler. I have formuler z11pro max (red light) it was bought for me ., do not no how supplier was , I will pay to get it fixed . Can anyone tell me what I do . As you no z11 pro max is not cheep .
Before doing anything, check whether it is an authentic Formuler device. Post an image or any information to confirm its authenticity. Then ask yourself what you installed or changed before the problem appeared.
Its already implemented on z12 ultra,expect it will also change with upcoming z11 update
Thank you. Another thing: when I turn on the box and press the right button on the remote to go to the next app, the remote skips the app immediately to the right and goes straight to the third app. I know it’s a minor bug, but we, the Formuler family, are still waiting for improvements.
Can we change the position of the volume bar from horizontal to vertical ? It gets in the way when subtitles are enabled.
I don’t have any movie applications any more to watch movies, just mytvonline2 and typical market place YouTube apps. How can I get my application back I think it was cinema-something
Cinema, support terminated. Use stremio.
Why look for an update when the system is stable?The only issue is that Android needs to evolve in order to allow the installation of applications.
I would like to install a 3rd party EPG since my providers isn't very good. I can find instructions for a MyTV 2 competitor on the web, but nothing for MyTV 2. Is it possible to install a 3rd Party EPG on MyTV Online 2?
Use vstro or ott navigator
I changed Nord VPN Server locations and also my Premiumize server location to OVH North America High Performance and Torrentio links reappeared.
Good news !
Can you play 4K movies with Stremio on the Formuler Z11 pro max ?
And with which settings ?
On my side, Stremio always forces FHD 1920×1080, even though my TV is 4K.
I have a mystifying issue that may be a Formuler Z11 Pro Max device issue ? My primary VOD streaming app is Stremio. It is setup with both Premiumize and Torbox debrid services using Torrentio, Comet and Media Fusion as scrappers. Approx. 1 month ago, Stremio stopped finding ANY Torrentio links – despite Stremio on my Buzz X5, Onn 4K Plus, and Windows laptop finding MANY Torrentio links from Premiumize and Torbox. The Formuler did find Comet and Media Fusion links but no Torrentio links. With Stremio being totally cloud based and not device based, I couldn’t think of any reason why the Formuler Z11 doesn’t see the same account details/links as all the other devices ?? So, I performed a factory reset of the Formuler and reinstalled and relinked all apps & also tried both wi-fi and ethernet connections. I’m still having the same NO Torrentio links. Other devices still always find MANY Torrentio links. My wife has learned how to use and navigate around the Formuler and really loves it. I hate to replace it with something new. Can you think of anything that could be causing this Torrentio “blocking” issue ??
Stremio is currently not available on the Play Store.
I recommend downloading the latest official version from the Stremio website, making sure to choose the Android TV version.
Also try changing the DNS (for example 1.1.1.1 or 8.8.8.8), as Torrentio is sensitive to DNS.
If you are using an ad blocker such as AdGuard Home or Pi-hole, the issue may also come from there, as some Torrentio domains can be blocked.
Finally, make sure to update Google services (Google Play Services, Android System WebView, and others) from the Play Store.
Use Kodi with the Elementum addon. Kodi runs very smoothly on the Formuler Z11 pro max. Additionally, Kodi supports OpenSubtitles.
