Hello, is it possible to add the Tizentube app in the MyTVOnline app under Settings > Trailers, because currently only YouTube and SmartTube are listed. That would be great. Thanks.
Mytvonline3 Trailers
- MYTVOnline3
- Z12 Ultra
Seatt -
May 17, 2026 at 3:19 PM
Hello, what is wrong with using YouTube or smart tube?
Mol3 has new update right? That the new smartube can be used?
Can you check in mol3 menu if there is written "smartube new"?
Download here new smarttube.
https://github.com/yuliskov/SmartTube/releases/download/latest/smarttube_stable.apk
Smartube isn't working. I have IP4 DNS checked, but it won't play. Tizentube works perfectly.
Blocking ads in Tizentube works perfectly without any glitches.
In mytvonline by settings trailer is the name SmartTube not smartube new i have install from the market
I thought mytvonline3 get updated so people can use the new smarttube. (Download from official website, in formuler market app is still old one)
Use beta version of mol3
HowTo Install:
After that you can setup the new smarttube in mol3 setting and install the smarttube i linked/posted here above my friend.
Okay, so I have to sideload it and then it will work? I'll try that, but I do think Tizentube looks really nice.
HowTo Install:
Oke i give it a try Thank you
See my post above yours. Delele old smarttube. Download new one from website and sideload it. Also download beta mytvonline3! That one can use the new smartube.
Download here new smarttube:
If you use vpn? Splittunnel smarttube my friend.
If you need more help.
Ask me/us.
Goodday
TizenTube Cobalt gives you the impression that you are using the official Android app.
Yes, true. But that one isn't implemented as option (yet) in mol3 and mol4 my friend.
I hope it will be added in the future. Thanks for the info it works. Have a nice day
Why not implement it as an external player? that case, we could choose the app we're interested in.
Well done my friend. Have a goodday too
I have one more question, how come the mytvonline app has been removed from the Google Play store?
Googles fault. But devs are busy with it.
Mytvonline android mobile/tablet
I can send it to you by private message.
Oke thank you for youre reply.
Posted it already here above your post.
Super thanks mate
HowTo Install:
The MOL3 & MOL4 beta is currently offline.
