Firmware v. 11.3.7 Hotfix Beta and MYTVOnline 3 v 12.1.42 BETA for Z 11 Series released
  • BETA Software Update for Formuler Z11 Series released.
    Firmware Version : 11.3.7 HOTFIX BETA
    MYTVOnline 3 Version : 12.1.42 BETA
    WARNING:
    If you don`t want to test, please wait until official comes out. No Forum support in other threads if beta in use, beta issues should be discussed only in this thread.
    HowTo Install:
    The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much longer than usual, please be patient and let the box finish the install. If necessary reboot later once again.
    Firmware v. 11.3.7 Hotfix Beta and MYTVOnline 3 v. 12.1.42 Beta discussions only in this thread here! Other open threads with Beta issues will be deleted instantly!
    We need to collect data and feedback's on one place, thank you for your understanding.
    Change Log:
    MYTVOnline 3 : 12.1.42 BETA
    • FIX: Rebooting issue when entering VOD & Series
    • FIX: Connection issues with some Stalker portals
    • FIX: Support for latest Smart Tube player in trailer player
  • MYTVOnline 3 : 12.1.42 BETA Is the mytv online version...
    The recording still does not work....
    Or is it a setting that i missed...
    Back to the old version of mytv online and the recording works perfect....
  • Belgiumuser
    Lemmingsbeest is right when Beta Firmware allow this and if older version of Mol work correctly all is fine. In some cases new MOL version is coupled with new firmware and older version then doesn`t work correctly but possible to install (Beta time). Depends all from changelog.
    How ever, when official comes out you can not roll back anymore to older version, because then is the last official installed only shown in update app or market.
  • Does anyone know whether in mol3 on XC connection,it is possible to set epg mode to alternate,and thereby have a full epg guide?
    Just like in mol4 beta.
  • It isn't written at the mol3 beta updates changelogs. So i'm almost sure it's not in mytvonline3.
    Goodday my friend
    It also wasnt written in changelog for beta mol4,but it was a coicidental finding by SAM,who was playing around with different settings in content sources,so i was wondering if updates in mol3 for z11 series have similar option,edit.>epg mode>set to alternate>have a full epg guide???:winking_face:
  • It also wasnt written in changelog for beta mol4,but it was a coicidental finding by SAM,who was playing around with different settings in content sources,so i was wondering if updates in mol3 for z11 series have similar option,edit.>epg mode>set to alternate>have a full epg guide???:winking_face:
    Unfortunately not :frowning_face:
    The "alternate" mode still doesn't work in Xtream Codes on the latest MOL3 beta on Z Mini.
    Personally, I only have one day forward and one day back.
    I had sent a message to the developer to see if they could implement this fix on MOL3 as well, but their response was generic and off the mark.
    It would be nice if the search by actor name worked on MOL3 in XC, as it does in Stalker, but that’s not the case either.
    It seems to me that this also works on MOL4... (And on other competing apps...)
    But I no longer have a Z12 to test that.
    I didn't notice that. Maby it's only a mol4 option yet...
    Edited once, last by Lucky13 (July 6, 2026 at 9:59 AM).
  • It worked I remember at my side on mol4 AFTER the automatic content updater at 16.00 hours what i setup in settings the next day.
    when i did manual epg update (in beta 1 version) it didn't working immediately.
    next day then when the auto content updater did his work, it was updated and a saw then it worked out. The epg some day forward😀
    Maby in beta 2 you need to wait too, till the message on your screen comes "new content found" after apply it's maby there the full epg.
    Edited once, last by Lucky13 (July 6, 2026 at 10:35 AM).
  • The developer option on MOL3 & MOL4 has been removed purposely for security reasons.
    Please let me know more details about your use cases on the developer option. We're looking closely into the feedbacks for now.
    Window/Transition Animation Scales: You can change or turn off system animations (setting them to 0.5x or 0x) to make your device feel faster and more responsive
    Performance mode and Window/Transition Animation Scales: You can change or turn off system animations (setting them to 0.5x or 0x) to make your device feel faster and more responsive
    We speek about MOL3 here, for Z Mini and Z11 serie, not MOL4 beta2.
    Contrary to what I said the other day about MOL3 (one day back, one day forward in the EPG), we actually have several days back (but still only one day forward) if the box is plugged in and configured.
    I no longer remember in Stalker if the EPG is complete from the start without having to leave the box plugged in for several days.
  • We speek about MOL3 here, for Z Mini and Z11 serie, not MOL4 beta2.
    Hi,afaik for mol3 on Stalker,you can switch epg mode to alternate,and thereby have full epg guide,several days ahead and back,almost immediately.
  • Hi folks,
    Just for your information, I installed the latest update on my Formuler Z11 Pro yesterday.
    The firmware update to version 11.3.7 went smoothly, as did the MOL3 update to version 12.1.42.
    On my side, everything is working well so far. 👍
    I’m using a Stalker portal, and I have noticed better overall smoothness.
    The interface feels a bit faster and everything is working fine for now.
    Of course, it has only been 24 hours since I updated, so it’s still a bit too early to make a final judgment, but so far everything looks good for me.
    I’ll post another message if I run into any issues.
    Thanks to the development team.
    Yes you're right.
    I told only that the "alternate" option worked at my side after the automatic refresh/update. (In mol4) not when i refreshed the epg manually.
  • Hi There, I have a friend with a Z11 Pro and I installed his streams (2 of them). The device is brand new and yesterday (with the BETA Firmware installed) MOL3 no longer loads. It attempts to load then crashes back to home screen. Any thoughts?
  • Hi,afaik for mol3 on Stalker,you can switch epg mode to alternate,and thereby have full epg guide,several days ahead and back,almost immediately.
    Okay, thanks for the confirmation that one of the advantages of connecting via Stalker in alternating mode is having several days of programming both past and future in the EPG, along with actor search in VOD :winking_face:
    Are you sure that you have several days available in the past even when adding a new subscription/server without having to wait several days for it to "load"?
    Edited once, last by Myst13 (July 7, 2026 at 7:22 PM).
  • Okay, thanks for the confirmation that one of the advantages of connecting via Stalker in alternating mode is having several days of programming both past and future in the EPG, along with actor search in VOD :winking_face:
    Its a long time ago i had Stalker connection for Z11/mol3 series,but i am fairly sure the epg guide loaded almost immediately:smiling_face:
  • How is the status with developer mode inside MOL3. Still message to disable? I need it for monitor over local network with scrcpy. ITS SAFE!!!! my local network is safe, please allow it!!!
    Or at least can i stay with the old release? Or are you going to even make us download the new version or it won't open??
    Let me just tell you this is an amazing move backwards, not allowing stuff due to security reasons (and not telling us what kind of security reasons) instead of improving it's outstanding. Good luck selling your products in the future!!!
    Which feature from the dev mode do you use?
    FYI, the Z11 was stuck and just crashed... I ended up doing a factory reset and everything back working normal
  • hi
    FYI
    I didn't mean to take this Beta this time as I didn' have any problems. A few weeks ago I started having problems with one of my providers. Vods didn't play (no image & no movie info), live tv and series were fine. Provider said all was ok on their end, same with alternative url. So I finally installed the Beta and all vods are loading/playing again. Using XCAPI.
  • I tested this beta, it has the same problem as before, when I record a program, the program does record but then the recording is broken, otherwise this beta and the software works well in my opinion. I have a Z11 Pro max
  • MYTVOnline 3 Version : 12.2.0 ΒΕΤΑ
    When I installed this beta. and then I reset it to factory settings. And I tried to launch MYTVOnline 3, He just scolded me that this device is not compatible with this app. But then when I installed this beta version after everything works again. Except that recording doesn't work now.
  • Same problem here i now have a formuler z11 pro max and no recording possible.....(and i use it very much)
    I have reported this several times and now is it complete broken and not usable for me (the recording part and i can't go back)...
    Please fix this problem.....
    Someone tried to format an usb stick with Rufus on windows and formatted it to Exfat or Fat32 (instead of NTFS)
    And it worked out for him!
    Give it a try my friend, im looking forward to your feedback.
    Goodday
    Edited 2 times, last by Lucky13 (July 15, 2026 at 6:55 PM).
  • I found that it works. But I will have to make a new station, but hopefully it will not be changed. Until now, however, it worked NTFS type
