Posts by Sunny07
With formuler z7+
For me mytvonline has problems with codecs, plugins with some sources live videos. Because with other applications iptv install on the formulate, it is fluid to you.
It's really annoying this problem of fluidity on some channels, is a big update on mytvonline expected soon? Thank you.
C’est vraiment énervant ce problème de fluidité sur certains canaux, une grosse mise à jour sur mytvonline est-elle attendue sous peu? MerciLe plus grand centre commercial
It looks like a compatibility problem between the source of my IPTV provider and the mytvonline app. Because when I test another provider it works the image is fluid while on my supplier on certain channel in HD or hevc it is not fluid, it makes slowdowns. And when I try my subscription with an application on the z7 + formulate this is fluid too. So it's a compatibility problem with mol.
With the application stb emu install on the formulate it is fluid but with mytvonline on some channels that sport is not fluid.
Sorry I'm French I use a translator. Not my father and I are not in the same house and therefore not the same router. I did not touch any settings, I even made a reset. On a video we do not see the image that bug. I shut down the reflex applications every time.
yes I tried in wifi and ethernet no change. The image is making **** -
Hello everyone, I come to you to solve my problem. My father and I both have a z7 + formula with the same subscription. On some sports channels the image is not fluent, and even more so on the HEVC sports channels. We are both over 20 mega. At a friend who has the same subscription on a 256 mag everything is fluid even the chains hevc and he has only 13 mega. So I think it comes from the mytvonline app. It annoys me because I really like this application, just this annoying problem. Thank you in advance for your answers.
Hello, when I watch TV with Mytvonline, when I press the vformat button nothing happens on the most parts stringsapart from two or three chains or this changes the format of the image. However it shows very original, panscan etc when I press it and so I wanted to know if there were settings to performf for it to work on all channels. I also noticed when you press the vformat button a menu is displayed with image settings and I wanted to know what are the optimal settings to make the image is as fluid as possible. Cordially.
since I changed the hdmi cable, that I put a powerful, it seems to work great! It remains more than solve the problem of EPG and it will be perfect the Z7 +!
okay tomorrow i get a new hdmi cable, i test that and i tell you all that. I bought this cable: https://www.ldlc.com/fiche/PB00233442.html
Hello, I have a problem with my formuler z7 +. When I'm on the MYTVONLINE app and I watch TV, every hour, once or twice the image cuts out at once for 2, 3 seconds and it comes back know where it can come from ? The last time I watched a movie on VOD and suddenly the movie was reset. And the EPG is still slow to show thanks.
ok and how to adjust the buffer value? Thank you for your answers.
Hello, when I watch tv with mytvonline support, from time to time the picture slows down two to three seconds and returns to normal. It only happens to me with mytvonline, when I use another iptv application it does not. Would you have a solution to my problem thanks. I have 16.5 mega debit internet.
What do you think are the best picture and video [lexicon]settings[/lexicon] for the z7 +? Thank you
Thank you for all your answers. Have a good day.
Ok thank you. And after there is no adjustment to be made in the parameters for the decoder to be at the top, for example buffering, audio, video, network etc...
Hello, I would like to know if someone to a tutorial to perfectly configure the Z7 + or if someone could tell me the best configuration for this case. Thank you.
Okay so I'm going on the z7 + it seems to be the best of what you tell me. Where to buy z7 +
So between the formuler Z and formulers S which are the best for IPTV ? It's better than Pu 377 or not ?
The series formuler F and Enigma 2 is better than z7 + or not ? Thanks you for all answers.
Okay, z7+ is he the best really ? Better than all décoder ? Thanks for your answers
Bonjour, je poste ce sujet car je souhaite avoir vos avis sur les formulers. Je souhaite passer de mon mag 254 à un formuler mais il y en a beaucoup et je ne sais pas lequel choisir. Je voulais donc savoir selon quel est le meilleur formuler pour l'IPTV merci à tous .
