Hello everyone, I come to you to solve my problem. My father and I both have a z7 + formula with the same subscription. On some sports channels the image is not fluent, and even more so on the HEVC sports channels. We are both over 20 mega. At a friend who has the same subscription on a 256 mag everything is fluid even the chains hevc and he has only 13 mega. So I think it comes from the mytvonline app. It annoys me because I really like this application, just this annoying problem. Thank you in advance for your answers.
Problem fluidity image
- MYTVOnline1
- Z7+
Sunny07 -
November 3, 2018 at 2:36 PM -
What do you mean with fluid, picture stucking or stuttering, buffering?
Did you try with other connection LAN<->WLAN?
yes I tried in wifi and ethernet no change. The image is making **** -
Please use normal words to describe the problem, bad words are not helpful (edited)!
1. Are you and your father in same house and connected to same router?
2. Is the last FW and Mol version in use?
3. Did you change some setting on MOL side?
4. Could you please upload screenshot when it happens to know exactly whats going on.
5. Before you start MOL, hold Menu for 2 sec. (home screen) and close all other apps, then start Mol and test again.
Sorry I'm French I use a translator. Not my father and I are not in the same house and therefore not the same router. I did not touch any settings, I even made a reset. On a video we do not see the image that bug. I shut down the reflex applications every time.
My z + is with 2 LEDs on and does not give any signal on tv!
With the application stb emu install on the formulate it is fluid but with mytvonline on some channels that sport is not fluid.
It looks like a compatibility problem between the source of my IPTV provider and the mytvonline app. Because when I test another provider it works the image is fluid while on my supplier on certain channel in HD or hevc it is not fluid, it makes slowdowns. And when I try my subscription with an application on the z7 + formulate this is fluid too. So it's a compatibility problem with mol.
C’est vraiment énervant ce problème de fluidité sur certains canaux, une grosse mise à jour sur mytvonline est-elle attendue sous peu? MerciLe plus grand centre commercial
It's really annoying this problem of fluidity on some channels, is a big update on mytvonline expected soon? Thank you.
March
I had a similar issue to start with watching FHD and 50fps streams, I changed the resolution to 1080P 50Hz and that seems to have sorted the stuttering issue for me.
For me mytvonline has problems with codecs, plugins with some sources live videos. Because with other applications iptv install on the formulate, it is fluid to you.
With which box?
With formuler z7+
With formuler z7+
Did you fix the problem? I'm having same issues
