Posts by freedom35
£172.50. In Canada. The GTV FORMULER
Holy shit that's close to $300 canadian. Who in their right mind would pay that for what it offers over the Z8?
I have 2- Z7+ boxes and 1 Z8. Very happy with all of them but the Z8 is my favorite. Have had no issues with either. MTVOL and MTVOL 2 are both the best IPTV apps out there!
Desired # 347
Is new to me but wired that the settings change. I would say, clear cache and clear data then hide the category's again. Provider dashboard gives you also the possibility to turn on/off category`s.
Same problem here with with both MTOL and MTOL2. They randomly come back after editing them.Cleared cache and data same result
Connection -> you sub ->Edit -> change from Normal to UTC and use offset time if needed.
Makes no difference
Yep has been an ongoing issue with me too with Mol 2. l also have 2- Z7 with Mol 1 and the guide is fine.
I agree I am having issues with the EPG also with MTOL 2. It's fine on my Z7+ .
If you have a Z8 there is no sd card slot
If your m3u links are long URLs that contain username and password parameters, just add them as normal xc api portals using the username and password credentials.
Wish I knew how to do that.
Well its been almost a year since this thread was started. Are there any plans to add any requested features such as the ability to add more than 1 m3u portal?
Display More
Sorry to say, but you need to do factory reset in this case and install again.
BTW.
In first post stays:
WARNING:
Other thread deleted.
First post:
* Beta definition:
Some beta software is only made available to a select number of users, while other beta programs are released to the general public. We have decided in past to open Beta for all interested Beta Users and public.
Each one can participate and post his feedback in open threads like this but should first read complete text and the warnings. We collect beta feedbacks in future only from extra opened thread like this (at one place and not allotted trough many different threads) here in Forum. Formuler have also other channels and receive feedbacks from Testers all over the world but this have nothing to do with forum.
For the final release, there will be improvements to reduce server bans due to flooding.
I understand it's a beta fix, I'm not complaining I just wanted some help on what to do to get the box back up and running which I have now. Trying it out now and so far its ok other than the EPG is not working with m3u playlist.Its fine if using a mac portal
Well i finally got mine back working with the beta firmware.Seems ok so far other than the EPG does'nt work when using the m3u playlist. EPG is fine with the mac portal.
Well never worked for me still stuck at the software update screen and will not install. Box is junk now I guess.What a disapointment
When installing the beta after restarting and launching MOL, I was constantly on the page of updates and impossible to have anything else and this despite several restorations factories, I had to do a hard reset physical via SD card for solve the problem. For my part the betas stop
Is there a how to on the hard reset with the sd card? Looks like thats what I'm going to have to do.
Having the same issue with my former z7+ using ****** IPTV service. No sync issues using the Perfect Player App with ****** so definitely an issue with the Mytvonline formuler app.
I have the same issue using the same provider
Yes only in MOL
Hello is anyone have problems with the remote control not responding all the time after the last firmware update? Sometimes when you pressing the botton to switch the channels nothing happens, you have pressed 7-10 times until is start responding and menu moves. Its happen randomly
Yep I am having the same problem since the last update
Be able to add multiple M3U portals
Just wondered if it would be possible to add the the option to of another portal to use another M3U playlist in the next firmware update.
Yes I agree on the ability to add more than 1 m3u list portal
Same issue here
Menu then select portals then edit portal
I am not having any issues with mine. More than happy with it
Doesn't work for me just says current version is latest which is V1.9.35
Got it, rebooted box and now it updated. Thanks!
in the main menu, click on the gear (settings) then on UPDATE then press RED button on remote to view beta update then press OK to download it.
How can I download and try this beta release?
