Any idea why the full EPG is showing different programs than the single EPG? It’s only for certain channels and they seem to be off by 6 hour or so (meaning if I scroll forward or back, it then lines up for that single channel but the others are then wrong). I’ve tried UTC and normal mode, adjusting the EPG offset. Fixing one messes up the others. Provider insists they’re not wrong, and using other apps on the firestick support them. I’m at a loss.
EPG not matching Single EPG
I agree I am having issues with the EPG also with MTOL 2. It's fine on my Z7+ .
I have the same problem. The strange ting is that this only happens with Portal connections. If I use m3u URL the epg is correct but I prefer the portal connection since that can sort series. With m3u series is useless since the appear in a big chunk with every series an episodes.
So portal connection is the way to go.
Can you please fix this epg issue.
Changed already to UTC EPG under Connection-> Subscription?
Same problem here since the update. I’ve tried everything, cleared data/cache, deleted and reinstalled portal, went from normal to ITV and back to normal and even did a factor reset. Some channels epg is right while others are off, do a time offset to fix them then the others are off. Nothing is wrong on my providers end. It has to be something with the last update.
Another issue is the main epg doesn’t always match the toolbar epg.
I have exactly the same problem
Différence 2h between EPG and EPG simple, I'm going to be crazy ! On m'y Z8 and also Z7+.
Has anyone found a solution ?
I am also having this same issue, except on when viewing full EPG I have channels that EPG shows in Spanish, but if I goto the Single EPG view, it shows the same shows but it is in English how it should be. I have no issues with other IPTV players on the same channels
Too same, on MOL2.
Stalker 5.0.3. -
yes same here on all models mol1 and mol2 (Nano,Z8,Alpha)
what was changed within the last updates ?
grid_epg not showing same like simple epg
catchup useless now. Its not a provider thing. we have players like smarters works wit xc login perfect.
so is formuler an issue.
so i just found why happens this.
when using XC login portal then the issue happens.
on both mol1 and mol2.
this have to be fixed then.
when used /c stalker portal login thru macadress then all works fine, but then „cloud timeshift" and such newer features not working.
we have clients that usw 2 or 3 Boxes (not simultan just one by one) at home with 1 subs, for that reason xc login is the preferred way.
pls fix this problem
the catchup epg is 2h behind the grid epg and event id.
SAM any word on if any of the developers can recreate this issue? Still happens after latest Hotfix: FW 1.4.73 - SW 7.9.3 on both Z8's in MOTV2, but other IPTV apps dont appear affected. I dont mind creating a ticket + to show what is happening!
Yes please, open ticket and provide screenshots with detailed description.
I am new to Formuler TV and have a question regarding the TV guide being out of sync to the time.
The problem is the guide is 8 hrs out to live TV , I have followed the steps to change the time ,
but the maximum range of time movement is 7 hrs ? So after doing the changes my TV guide is still 1hr
different to live TV, any help on this matter would be appreciated
Hi Guy's
I have a formuler Z8 with two different IPTV provider's. One supplier is connected using the MAC code. The other user is connected using the portal URL and using the password that was given to me with my subscription.
Only the MAC code connection shows the correct start time within the EPG which also matches the same start time as shown when opening the information data.
I guess it's worth trying to connect using your MAC address and ensure the time UTC offset for your location is selected within the portal connection
This is the same for me!
